Oil Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jmbg, Mar 11, 2024.
  1. Mar 12, 2024 at 12:05 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    ^^^ this....i choose not do it myself, dealer has done it so far with NO PROBLEMS, if the toyota engineers think 10k is ok then ok, they are smarter than anyone here on what is ok for the engine, i do it once a year which is about 8 or 9 k.....but owners should know how its done so they know if there is a problem
  2. Mar 12, 2024 at 12:53 PM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    You are correct...you have already paid for the service when you purchased the vehicle, so get your monies worth.
    I've been turning wrenches on vehicles for over 40 years. Do I complete most services myself given the time and experience needed, yes; however, if a service is included...belly up and enjoy.
    It is the OP's prerogative whether or not to utilize this service.
    Cheers
  3. Mar 12, 2024 at 3:39 PM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    It is OP prerogative - but for something simple and important, I wouldn't take the risk.
    Belly up n enjoy till they f**k your truck up and then :eek: mo problems than the included service saved ya.
  4. Mar 12, 2024 at 3:52 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    No dealer services for me.
    No 10k OCI for me either……5k, RTFM
  5. Mar 12, 2024 at 4:19 PM
    B6P6P6
    B6P6P6 Well-Hung Member
    Brian
    Firestone,Colorado
    2023 Tacoma Sport
    Free is for me! Toyota did my first change @2880 miles. I will do my own @3000 mile intervals until my next free change from Toyota with Toyota oil and filters each and every time. I might not be a Toyota engineer but I will do what I think is best for my truck, after all it’s my truck and I’m paying for it. I also work at a truck stop and have changed oil on semi’s for over 37 years so my own vehicles are no problem, we also have an account with the local Toyota dealer so I get supplies cheap. At the end of the day do what you can, as often as you want, with what you think is best your Tacoma deserves it.
    Inyo_man, RIX TUX[QUOTED] and Jakerou like this.
  6. Mar 12, 2024 at 4:30 PM
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    OEM filters are cheaper from dealer than Wal-Mart. And the dealers use Mobil 1 so you can't go wrong with that.
    B6P6P6 likes this.
  7. Mar 12, 2024 at 4:31 PM
    Otterstuff
    OEM filters are cheaper from dealer than Wal-Mart. And the dealers use Mobil 1 so you can't go wrong with that. I also recommend replacing the plastic housing with an aluminum one.
    B6P6P6 likes this.
  8. Mar 12, 2024 at 5:00 PM
    B6P6P6
    Brian
    Firestone,Colorado
    2023 Tacoma Sport
    Toyota oil filters are sometimes buy 5 get the 6th for free! From the dealer.
  9. Mar 12, 2024 at 5:16 PM
    Clearwater Bill
    Billy
    Largo Florida
    Knew a guy with the same philosophy about what his Dr or dentist suggested. That he knew better because he'd read the farmers almanac and helped deliver a couple of foals. When he saw the cost for his dentures he had an aneurysm because he took fish oil instead of BP meds
    :cool:
    Also remember Toyota doesn't make filters. They are Toyota branded by the low bidder for the current contract.
    Any oil and filter that meets the OE spec is fine. And you cant go wrong using the duty use OCIs found in your owners manual.
  10. Mar 12, 2024 at 5:32 PM
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    Just picked up my 2019 Tacoma and will have to change the oil soon and will want to reflect on this.
  11. Mar 12, 2024 at 5:44 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    first of all make sure you drain the oil and not the tranny fluid, has been known to happen.
    make sure the O ring is seated it the right grove. look at the old one before you just remove it.
    wipe some oil off your finger onto the O ring and the threads after it is in place. 'O ring in place on the cap'
    tighten the cap to 18 foot lbs, mine bottoms out at 18 foot lbs.
    after adding oil start it up before putting the skid plate back on. run for a bit and check for any leaks from the filter cap.
    install skid plate and done.
    pdxTacoSR5 and Hardscrabble like this.
  12. Mar 12, 2024 at 6:06 PM
    B6P6P6
    Brian
    Firestone,Colorado
    2023 Tacoma Sport
    It’s just I can buy Toyota brand cheaper than box stores because I have an account there, I’m sure there’s better but there’s a whole lot worse also, for sure. New filter and fresh oil always seem to make my truck run better, you all have had the same feeling of accomplishment just after doing it or having it done .
  13. Mar 12, 2024 at 7:19 PM
    Bravesfan1995
    Bravesfan1995 Well-Known Member
    Ashley
    2023 Tacoma TRD off-road Ice Cap
    I had to fight the dealer to let me use my 10k service at 4600 miles. They were trying to make me pay out of pocket instead. I was frustrated… but eventually my service manager realized I wasn’t going to fall for it.
    Otterstuff and Inyo_man[QUOTED] like this.
