Oil changes 2023 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by glazier88, Apr 30, 2023.
  1. May 1, 2023 at 5:22 PM
    #41
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Ha…..well I did go to ABDR school
    hiPSI[QUOTED] likes this.
  2. May 1, 2023 at 5:35 PM
    #42
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I agree, it can take a long time to learn on your own too. Nothing like being an apprentice on the job to get you up to speed.
  3. May 1, 2023 at 6:01 PM
    #43
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    tighten the filter cover to 18ft lbs. wipe some oil on the threads in the filter cap.
    faawrenchbndr likes this.
  4. May 1, 2023 at 6:11 PM
    #44
    DVR
    DVR Well-Known Member
    SC
    23 TRD Pro
    It does for me.
    I completely remove it. Way heavier than the one on my former TRDOR.
    The pro plate has access holes. Doubt I could do a oil and filter change w/o a mess with plate installed.
    Wasn't so easy to put back up alone. An extra set of hands would be a huge help.
    I did my first at 2000 miles. Will do second a 5000 miles.
    Then every 5000 for the rest of our relationship.
    I use oem consumables and kirkland synthetic 0w20.
  5. May 2, 2023 at 4:22 AM
    #45
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    It’s doable with the skid plate installed. Certainly wouldn’t remove it for a an oil change.
    skidooboy and zoo truck like this.
  6. May 2, 2023 at 5:00 AM
    #46
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Excellent choice. Overkill, but who doesn’t like a few more tools in the garage. I have the same setup and that oh so controversial ‘f’ valve. Changes are a breeze and super clean.
  7. May 2, 2023 at 8:56 AM
    #47
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Its probably one more thing you'll throw away when we all end up driving EV's.
  8. May 2, 2023 at 9:01 AM
    #48
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I’m not sure those who perform oil changes are certified. You may think they are skilled and don’t make mistakes too. This forum is littered with example after example of oil change problems.
    22Coma6MT likes this.
  9. May 2, 2023 at 9:24 AM
    #49
    glazier88
    glazier88 [OP] Well-Known Member
    2023 white tacoma trail
    Speaking of oil should I start full synthetic at 1000 mile change? Or run more miles on the engine first?
  10. May 2, 2023 at 12:11 PM
    #50
    mquibble
    Michael
    2021 TacomaTRD Pro
    Nope. Makes it easier
    skidooboy likes this.
  11. May 2, 2023 at 12:20 PM
    #51
    zoo truck
    None
    Do yourself a favor and skip those 1000 mile oil changes, they might have been popular with the dino break in oils of the 50's and 60's, but much has changed since. Replace the oil at the first 5k miles with a quality 0w-20 synthetic, and 10k, or a year after that if not in the extreme use bracket.
  12. May 2, 2023 at 1:35 PM
    #52
    glazier88
    Thanks. I’ll probably go with every 5000 quality synthetic.
    RushT likes this.
  13. May 2, 2023 at 2:12 PM
    #53
    RushT
    North Texas
    Dunno, I went full right away but I’m no expert. I’ve heard stories of changing to synthetic late in life (75k miles) causing leaks. I’m not convinced, but have heard it.
    There may be something to running dyno oil for a bit more break-in up front, but I have no idea how to quantify that. My best scientific advice is do which makes you happier as you’ll unlikely be able to tell the difference between switching at 1k vs 10k.
  14. May 2, 2023 at 2:41 PM
    #54
    glazier88
  15. May 2, 2023 at 2:44 PM
    #55
    glazier88
    I’m thinking 5000 start full synthetic. I haven’t heard any thoughts that would change my mind.
    They say it can’t hurt on everything I’ve pulled up.
    I mean how has it worked out for you?
  16. May 2, 2023 at 2:48 PM
    #56
    YatYas1833
    YatYas1833 Well-Known Member
    22 WHITE TRD OFFROAD 4x4 DCSB
    King 2.5’s with adjusters from accutune front and rear, 88 rotors rear add a leaf, Camburg X-joint UCA’s, Factory style trd pro 16” wheels with 0 offset, 285/75/16 KO2’s, pro grille, Front bumper viper cut, trd front skid plate, full RCI under skid plates, Cali raised trail sliders, exhaust cut dump, KDMax 10.0 tune
    Just change oil every 5k miles with full synthetic and you’ll be fine. The whole changing at 1k miles is BS
  17. May 2, 2023 at 2:49 PM
    #57
    RushT
    North Texas
    I’m at 75k with synthetic from 5k onward at 5k intervals. A few blackstone samples have come back just fine. I don’t send each change off (probably should). Engine seems just as quiet as new, with very little ticking and valve train noise. That’s about all I could tell you. Qualitative, not quantitative.
  18. May 2, 2023 at 2:51 PM
    #58
    RushT
    North Texas
    I wonder, does 80mph Texas commuting qualify as extreme? If so, I’m right on schedule with my 5k changes.
  19. May 2, 2023 at 4:55 PM
    #59
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Having, and installing the oem TRD Pro (not knock off) skid plate, is way better than the stockers on the OR, and Sport. you just drop the access cover, and do your thing. there is no need to remove the whole pro plate for a basic oil, filter change. the only reason to remove it would be, to access the front diff for fluid change, or lower engine, suspension access.
    as far as oil changes, get the first one done between 1500-2500 miles, get the machining, and mating BS out of the oil/filter, way before 5-10000 miles. the first oil change is the most important, to me. then go to 3-5000, then 5-7000. Personally oil and filters are cheap, and are worth the price of the insurance that you have good clean, oil and filter. it will help the motor last longer. there is no way I would go 10000 miles on an oil change. Ski
  20. May 2, 2023 at 5:34 PM
    #60
    glazier88
    Thanks
