Oil changes
Discussion in 'Technical Chat' started by my coconut, Sep 27, 2009.
  1. Sep 27, 2009 at 9:32 AM
    my coconut
    my coconut [OP] Member
    rick
    nor cal
    05 tacoma trd 4x4
    I have a 4.0 l tacoma 4x4 . I use mobile 1 synthetic 5w30. I currently change it every 6,000 miles or 6 months. Its my understanding that synthetic oil will last this long. Or should i be changing it at 3,000 or 3 months. Any feedback would be appreciated.
  2. Sep 27, 2009 at 9:34 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    i do mine every 5k miles, also on mobil 1
  3. Sep 27, 2009 at 9:44 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I do mine every 15K miles, with Amsoil Synthetic. I'm able to go to 25K, but I just do it at 15K.
  4. Sep 27, 2009 at 10:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I change mine (Mobil 1) at between 3000 and 4000 miles. My oil samples have come back showing less than 50% usage, so you will be fine going that distance. Have your oil tested to be sure, as conditions vary. :)
  5. Sep 27, 2009 at 2:53 PM
    JATaco
    JATaco Well-Known Member
    Las Vegas
    tacoma prerunner
    What aboout mobil 1 extend performance? It claims 15k protection.
  6. Sep 27, 2009 at 2:57 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    no matter what kind of oil you use, its always a good practice to change every 5000 miles. or, for older trucks, every 3000 miles
  7. Sep 27, 2009 at 3:34 PM
    JKD
    JKD Well-Known Member
    If you run oil analyses on Mobil 1 (and probably other quality synthetics) you will probably see that the oil is just fine up through 12-15,000 miles. I wouldn't do it under warranty, though.
    On my last car I was running 10,000-12,000 mile intervals. My oil analysis at 8,000+ miles showed all contaminants well below limits, oil viscosity was still within normal limits, and additive package was still working fine.
  8. Sep 27, 2009 at 4:22 PM
    my coconut
    rick
    nor cal
    05 tacoma trd 4x4
    not sure where to send the oil to have it checked
  9. Sep 27, 2009 at 4:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Many places have a "Kit" they send you at no charge. Just follow the instructions, and send it to them. They charge a fee for the test. Check your local phone book, or online. I know Polaris Laboritories does oil samples. If you have a local Caterpillar, or John Deere dealer, they can also do it for you.
  10. Sep 27, 2009 at 7:44 PM
    JKD
    Blackstone Labs (google it) will send you a sample kit for free. You send it back with a check (or credit card info) for $22.50 and they send you back your analysis.
  11. Sep 27, 2009 at 7:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    BINGO! I was trying to remember them. :eek:
  12. Sep 27, 2009 at 7:48 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I run Mobil1 and change mine every 5k.
    Do you use the same oil filter the entire 15k? Or do you swap it out at 5k 10k and again 15k? Or maybe half way 7.5k?
  13. Sep 27, 2009 at 9:08 PM
    JATaco
    Las Vegas
    tacoma prerunner
    So it not worth spending the extra $ for the extended perform mobil 1.
  14. Sep 28, 2009 at 12:24 PM
    bubba
    bubba Member
    Dave
    Cleveland Ohio
    TRD Sport Package
    Extended Performance or not the Oil Still gets dirty. If you read the fine print on
    Mobil 1 Extended Performance it basically tells you to follow the manufactures
    oil change intervals. Toyota recommends 5,000 mile OCI I think that's too long.
    I changed the factory fill at 1,089 Miles and plan to change next at 3,000 miles
    than every 4,000 after that using Pennzoil Platinum Oil. Yes that's overkill but
    Oil is cheap and engines are not. I also plan to run the truck to 500,000 or better
    and think that with Toyota's Quality that is easily within reach.
  15. Sep 28, 2009 at 3:39 PM
    JKD
    I trust the data I get back from oil analysis, which says that (on my last vehicle) at 8,000+ miles the oil was not outside of acceptable limits on any contaminants.
    I ran the last 100,000 miles on my previous vehicle using Mobil 1 with extended drain intervals, and the engine is still in excellent shape. There has never been any evidence of abnormal wear, despite me driving it pretty hard.
    Mobil 1 says to go with the manufacturer's OCI to stay kosher with the warranty, not because the oil needs to be changed. When Mobil 1 was introduced it was advertised with a 25,000 mile OCI.
