Oil changes ?????
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RLMoody, Jul 12, 2019.
  1. Jul 12, 2019 at 2:53 PM
    RLMoody
    RLMoody [OP] Well-Known Member
    2017 Toyota Tacoma SR
    In January I retired from my full time job that was 20 miles away and now work part time 4 miles from the house. Before I retired it was easy to schedule my 2017 Tacoma for oil changes based on the miles and time between oil changes. Since January the truck has been driven 2700 miles and I am getting notices that my oil change is due. It currently has about 23000 miles on it. Is it necessary to stick to the previous scheduled times ? With the miles I drive now it adds up to about 5000 miles a year. To me that is more realistic to do it once a year. I also have a 14 Sienna being driven about the same miles a year. I am interested in the pros and cons about this. What do you think?
    over60 likes this.
  2. Jul 12, 2019 at 2:55 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I change my oil once a year.
    over60 and daddy_o like this.
  3. Jul 12, 2019 at 3:02 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You might have noticed that you posted this in the 1st gen specific forum (1995.5-2004), however, this is not really a generation specific question. so here goes:
    Just do it whenever the dash tells you maintenance is required. That's why Toyota started doing that.
    For my first gen, that doesn't have that fancy screen to tell me when to do maintenance, I just do it about once a year. More/less depending on how much I drive it. It is a trail truck, not a daily driver now, so doesn't need to be done as often.
  4. Jul 12, 2019 at 3:47 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    I change my oil every 5000 miles which adds up to about twice a year for me. It also depends on what kind of driving you do, for instance if you drive in dusty areas you'll want to change it more often.
    Tullie D likes this.
  5. Jul 12, 2019 at 3:54 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I don’t put much more than 5,000 miles on the truck a year. I run synthetic oil and so just change it at the 5k mile intervals which is about a year.
    robssol likes this.
  6. Jul 12, 2019 at 4:04 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    I get mine changed every 5k miles because its free lol
    MinookaBlues likes this.
  7. Jul 12, 2019 at 4:06 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Oil changes should be done every 10k miles or 12 months, whichever comes first. Simple as that.
    Lawfarin, over60, Rustytaco71 and 2 others like this.
  8. Jul 12, 2019 at 4:09 PM
    daddy_o
    Bossier City, La
    Under Toyota care you will get oil changed once a year or 10k miles. Each 5k interval in between that is just a sunshine service. Unless you have something else worked out or work at a delaership, then that would be different.
    Wixo likes this.
  9. Jul 12, 2019 at 4:30 PM
    Good deal
    Good deal Well-Known Member
    Texas
    Is that with conventional oil as well or just synthetic?
    Wixo likes this.
  10. Jul 12, 2019 at 4:36 PM
    gus54
    gus54 Well-Known Member
    Gus
    Cleveland, Ohio
    2016 Quicksand Tacoma TRD Off Road
    Undercover Lid, BFG KO2 AT
    My dealership told me every 10k under normal circumstances with full synthetic. That's about every 10 months for me.
    Wixo, MinookaBlues and daddy_o like this.
  11. Jul 12, 2019 at 4:39 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I went the full 10,000 miles on my first oil change, however having a hard time accepting it's ok to go that long. I will probably go 5000 from here on out.
  12. Jul 12, 2019 at 4:43 PM
    daddy_o
    Bossier City, La
    3rd gen trucks interval, so synthetic.
  13. Jul 12, 2019 at 4:48 PM
    MinookaBlues
    MinookaBlues Well-Known Member
    2022 Super White SR5 Access Cab
    Stock
    My dealership told me this also. I put around 7,500 miles on my truck per year so when I take it in for the yearly inspection I have them change the oil then so I don't have to be at the dealership more than once a year unless needed ( I like to look at the new trucks way to much). The maintenance light comes on every 5,000 miles I believe....I just reset it.
    over60 likes this.
  14. Jul 12, 2019 at 4:57 PM
    Good deal
    Texas
    I agree. On my '03, however, I use conventional and change it somewhere between 4k-5k miles. The increased frequency forces me to lift the hood and look for other maintenance issues i.e., hoses, belts and other fluid levels.
  15. Jul 12, 2019 at 7:04 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    The owners manual recommends 5000mi OCIs for severe-duty use. If you do frequent towing, start-up, heavy payload hauling, Car-top carrier installed, very frequent short trips in extreme cold weather.
    I would also recommend you make sure that the oil you use, whether synthetic or conventional, is actually rated for the extended drain intervals of 10k+ miles. It doesn't hurt to get an oil sample analyses to help you better plan your oil changes.
  16. Jul 13, 2019 at 7:23 PM
    RLMoody
    Thanks guys. I think I will do it once a year or every 5000 miles which ever comes first in the future. The dealership was trying to get me to bring it in every 6 months . Ive also read somewhere synthetic oil only needs to be changed every 10000 miles which would be to long in my case. I just remember when you changed your oil every spring and fall and it was as simple has that. Getting old I guess.
  17. Jul 13, 2019 at 7:27 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    It's 10k OR 1 year. If you're hitting the year mark first then change it. If you're hitting the 10k mark first then change it. The manual is pretty clear on this.
    Wixo and daddy_o like this.
  18. Jul 13, 2019 at 7:32 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  19. Jul 13, 2019 at 7:42 PM
    specter208
    California
    Depends on your driving habits and the oil you use. If you do lots of short trips, city driving with constant acceleration and high RPMs your oil will wear out quicker. Not all synthetics are rated for 10,000+ miles and even then the oil will wear different depending on your driving habits as just stated. The best way to know is to pick an oil brand you would like to use and get it analyzed at certain mileage milestones and the lab will tell you how much life is left in your oil to properly schedule your oil changes.
    MtnFisher likes this.
  20. Jul 13, 2019 at 7:48 PM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    +1
    specter208[QUOTED] likes this.
