Oil Consumption
Discussion in '2nd Gen. Tacomas (2005-2015)' started by colton1808, Jul 11, 2015.
  1. Sep 15, 2015 at 12:30 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Tell me your secrets..
    colton1808[OP] likes this.
  2. Sep 15, 2015 at 3:02 PM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Lolololol
    No, you'd get black staining on the quarter panel from burning oil too. Yes, burning oil tends to create blue smoke and running rich causes black smoke and burning antifreeze/water creates white smoke. But that doesn't mean it stains things blue lol
  3. Sep 29, 2015 at 8:41 PM
    colton1808
    colton1808 [OP] Active Member
    Well I got 180 on all cylinders.....
  4. Sep 30, 2015 at 5:29 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    If the valve seals are bad, you get blue smoke on start up after sitting a few hours. The oil at the top of the engine leaks down into the cylinders and burns blue on start.
  5. Sep 30, 2015 at 6:26 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Have you check it for leaks? That's a pretty good engine my 97 had 285K and never burn a drop. Valve seals can cause smoke at start up (dead give away) but that does not end there. There is a lot of oil up top and if the seals are leaking the intake seals will allow oil in during the intake stroke driving down the road and it probably will not be noticeable.
