Oil consumption!
Discussion in '4 Cylinder' started by 2.7taco, Jul 29, 2017.
  1. Jul 29, 2017 at 4:01 PM
    2.7taco
    2.7taco [OP] Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Well guys and gals the 2.7 may be on its last leg. Oil consumption has gone from 1 quart for every 1000 miles to 1.5 quarts for every 600 miles. Even a mix of 5W-40 Rotella T6 was not strong enough to keep the oil consumption down to acceptable rates. I have 2 small seeps and now a 3rd on the rear main seal. Thinking ring pack may be stuck or failing/damaged. A lab sample will be going out after 1000 miles to see what is in my oil.
    Any guesses where the oil could be going or getting consumed?
    PCV is new as are several vacuum lines. Compression test a few months ago showed all 4 to be acceptable even with the throttle plate closed. No drips of oil anywhere under the truck.
    Oil currently in the engine is Mobil 1 Syn 0W-40 (just a touch thicker than 5W-30).
    Any places to look would be appreciated.
  2. Jul 29, 2017 at 4:04 PM
    MSCOFF
    MSCOFF Well-Known Member
    Mark
    CT
    2017 SR5 AC 4WD
    cooling system?
  3. Jul 29, 2017 at 4:05 PM
    2.7taco
    Texas
    I don't think that is an issue lol. Coolant is nice and pink.
  4. Jul 29, 2017 at 5:57 PM
    2.7taco
    Texas
    Any other ideas?
    All I can think of is a stuck or damaged ring pack or valve guide seals all tore up.
    wilcam47 likes this.
  5. Jul 29, 2017 at 6:00 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    valve seals, is it smoking out the exhaust under load?
  6. Jul 29, 2017 at 6:13 PM
    2.7taco
    Texas
    No smoke as far as I can see. The tail pipe does have oily heavy black soot around it. So that's why I'm thinking valve guide seals or a ring pack. Ring pack is possible since more seals are starting to leak but the engine still holds a good vacuum.
  7. Jul 30, 2017 at 1:45 PM
    2.7taco
    Texas
    May be doing a leak down test soon. Unfortunately don't have the tester so I'm going to find a trust worthy guy to take care of the test.
  8. Aug 2, 2017 at 12:11 PM
    dubveeyota
    dubveeyota Member
    Tony
    West By Gawd Virginia
    07 4x4 access cab base
    Following. I'm now adding about 3 quarts throughout the oil change cycle. No evidence of a leak, and haven't seen any oil smoke in the exhaust, but when I drive up a mountain to a particular job site, I can smell burning oil when I get out of the truck. That could be from a leak onto the hot block, though.
  9. Aug 2, 2017 at 3:46 PM
    MSCOFF
    Mark
    CT
    2017 SR5 AC 4WD
    leaking past the rear seal into the bell housing and burning off before it gets to the ground?
  10. Aug 2, 2017 at 4:35 PM
    dubveeyota
    dubveeyota Member
    Tony
    That's pretty much what I suspect. I never figured these motors would be prone to a leaky rear seal, but it's the best guess I've been able to come up with
  11. Aug 3, 2017 at 11:02 AM
    MSCOFF
    Mark
    CT
    2017 SR5 AC 4WD
    please post when you figure it out
  12. Aug 4, 2017 at 8:04 PM
    2.7taco
    Texas
    So far I cut my oil filter open on the Tacoma and no metal flakes or debris within the filter. So that's a positive note. Now to find where the oil is really going. I need a leak down test to be done.
  13. Nov 6, 2017 at 7:53 PM
    tacoma65
    tacoma65 Member
    los angeles
    09 tacoma 4cylinder
    Hello Guy's I just find out my truck 2009 Tacoma 2.7 ,141.000+ miles was empty motor oil .there's no leak under the engine only sipping oil by the valve cover I'm using pennzoil 10w30 is there any Problem with this Motor's?
  14. Nov 7, 2017 at 2:32 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    If your engine block or bell housing are getting hot enough to burn motor oil, your problems are more serious than just an oil leak.
    How long has it been since your last oil & filter change? Have you checked for a leak around the oil filter? No problems with these motors that I am aware of, at least none that would cause oil to simply disappear. Your engine might be burning small amounts of oil that could add up to large amounts if you don't check the level frequently. You should check the oil level every 2 fuel-ups if everything is tight -- check it more often if you have oiling issues.
    2.7taco[OP] likes this.
  15. Dec 4, 2017 at 6:06 PM
    2.7taco
    Texas
    Oil consumption or a severe leak are the only 2 things to cause that kind of oil loss within 5k miles.
    Also 5W-30 is the Toyota USA recommendation. I run 0W-40 which is just a touch thicker. 10W-30 will be much thicker at cold temps than a 5W-30.
  16. Jan 8, 2018 at 11:59 AM
    shawnster88
    shawnster88 Well-Known Member
    Shawn
    Defuniak Springs, FL
    96 Tacoma Reg cab 2.7 5 speed
    OME 881 coil springs, OME nitrocharger sport shocks front and rear. Nitro 4:56 gears. ARB rear locker. Shrockworks front bumper with Warn M8000S winch. 17x9 SCS Ray 10 wheels w/ 285/70/17 Toyo Open Country RT Trail tires. Corbeau Trailcat bucket seats. Go Rhino roll bar w/ KC Daymaker lights. GMRS Radio. Ham Radio.
    You figure it out yet? I just started experiencing similar problems.
  17. Jun 12, 2018 at 7:16 PM
    2.7taco
    Texas
    Unfortunately I have not. The consumption is at a steady 1 quart per 900 miles at this point running 0W-40 Mobil 1 Synthetic.
  18. Jun 26, 2018 at 2:59 AM
    B ill y
    B ill y Well-Known Member
    Billy
    Sarasota County, Florida
    2018 4Runner Trd OR, 1997 FZJ80,1985 FJ60
    I had a 87 toyota van .with the 4y engine 4cyl. and it used 1 qt per 100 miles and I had to change to spark plugs every week. it had bad oil seals on the pistons. the compression rings were good but the seals were bad. I drove it for 6 years like that . just bought the cheapest 20w-50 I could find and cheapest plugs. eventually I had to put it to rest cause I wore out the spark plug threads and couldn't change them any more but it keep on going.
  19. Jun 26, 2018 at 3:25 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The owners manual in mine says 1 qt per 600 miles is acceptable. I'm at 189,000 miles and so far never add oil except when I change oil. At 5000 miles after the last oil change I might be 1/2 qt. low. If I were using 1 qt every 600-1000 miles I might be concerned, but I'd keep driving it and just add oil until it got worse. Might get a lot of years out of it that way.
  20. Jun 30, 2018 at 9:01 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
