Oil consumption
Discussion in '3rd Gen. Tacomas (2016-2023)' started by webfoot56, Oct 31, 2020.
  1. Oct 31, 2020 at 7:23 PM
    webfoot56
    webfoot56 [OP] Member
    2019 tacoma
    Have a question for you tacoma owners what is your oil consumption on your V6 Tacoma.Have a 2019 with just a little over 7k miles. I had to put a quart of oil in it at 3200 miles. Notified dealer took in we changed oil. Now at 7200 miles warning light came on to add oil which I did it was at add mark on dip stick. Added oil, called my dealer am taking in on 11/3/20. It is not leaking but I think it smokes a little too much out the tail pipe for being 50 degrees out. Are these V6 motors supposed to behave like this?
  2. Oct 31, 2020 at 7:31 PM
    webfoot56
    2019 tacoma
    thanks gives me something to go on. Truck is under warranty want to make sure it gets taken care of by toyota.
    tacotoe and Vbpiper like this.
  3. Oct 31, 2020 at 7:33 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Your is the first I have ever heard of to use any oil. Take it in. I've read 15-20K threads here and you are the first I have heard about.
    tacotoe, Chew, fdbyrne and 7 others like this.
  4. Oct 31, 2020 at 7:39 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Something is definitely wrong .
    BMH, Chew and shakerhood like this.
  5. Oct 31, 2020 at 7:40 PM
    Raeburn
    Raeburn Well-Known Member
    2017 ORDCSB
    32,000 miles on mine, never added oil or even had the dipstick read lower than when the oil was first changed. This is not right, you need to take it to the dealer.
    BMH likes this.
  6. Oct 31, 2020 at 8:19 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Chew, Bleep100, Boghog1 and 2 others like this.
  7. Oct 31, 2020 at 8:22 PM
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    Liar only 14.237k
    hiPSI[QUOTED] likes this.
  8. Oct 31, 2020 at 8:28 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    The big D...
    Believe it or not I've sorta counted...
    tacotoe likes this.
  9. Oct 31, 2020 at 8:38 PM
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    There is something wrong with your truck. These trucks don't use oil like Chevy trucks do....
    Modesto Tacoma likes this.
  10. Oct 31, 2020 at 9:26 PM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    No oil consumption on my 2020 V6.
  11. Oct 31, 2020 at 9:32 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Different engine, but my '06 Taco with 126K miles uses no measurable amount of oil between services.
  12. Oct 31, 2020 at 10:24 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    This.
    Not normal for the 3 5
  13. Oct 31, 2020 at 10:29 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Almost 30k on my 18. Never add a drop between changes.
  14. Nov 1, 2020 at 2:40 AM
    Professor D
    Gregorny
    Mass
    Yes
    Yeah okay I’ve read your posts I doubt that you can count past 11
    Amanelot and hiPSI[QUOTED] like this.
  15. Nov 1, 2020 at 3:01 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Not normal. All modern engines use some oil, but I've never had to add any at 29k miles. Maybe look into your PCV valve. The 5.0L V8 for Ford began consuming oil after they reworked it in 2018. Some have reported the PCV Valve was their issue.
  16. Nov 1, 2020 at 4:20 AM
    TacomaBeast67
    TacomaBeast67 Well-Known Member
    Calgary, Alberta
    2017 TRD Sport, Dbl Cab, Manual
    K&N Cold Air Intake, N-Fab Rock Rails, Removeable Steps, BAC Revolver X2 tonneau, 265/70/17, engine bay LED’s, Amber/clear strobes
    My 17 TRD Sport never used oil between oil changes in its 134k odometer. This isn’t anything you have to “get used to”, “live with”, or “put up with”.
    Don’t take any service resistance to act on your behalf from the dealer. You get any push back from the dealer, call up cooperate, they’ll deal with them while they have you on hold. Make them accountable for their product. You’re paying the mortgage.
    tacotoe likes this.
  17. Nov 1, 2020 at 4:44 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Some engines use some oil, others don't and it doesn't necessarily hurt anything if one uses some. I've never had to add oil to my 2007 other than when changing oil. But sometimes it is getting close to needing a quart at that time.
    While most use less, if you're only adding 1 quart every 3000-3500 miles I'm betting Toyota tells you that is well within what they consider acceptable. Some manufacturers don't consider it a warranty issue unless you're adding a quart every 1000 miles or less.
    Plain Jane Taco likes this.
  18. Nov 1, 2020 at 4:51 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Pulling the spark plugs will tell you if the engine is burning oil.
    Chew and Boghog1 like this.
  19. Nov 1, 2020 at 5:08 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes there is an issue.
    tacotoe likes this.
  20. Nov 1, 2020 at 5:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    Let Toyota diagnose and repair it, then let the board know what the deal was.
    Your situation is not a known issue on 3rd gens, and of course doesn't have enough miles to have normal wear based consumption.
    Anything any of us says here is just speculation of why at this point, but the main thing is you shouldn't be touching it for any self diagnosis or repair.
    Hopefully it's simple, but that's not really likely.
    GL and keep us posted.
