oil consumption
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glidestreet, Sep 25, 2021.
  1. Sep 25, 2021 at 2:08 PM
    glidestreet
    glidestreet [OP] Member
    Donald
    BLACK 2009 TACOMA 4X4 ACCES CAB
    none
    so we did a cylinder compression test on my 2009 tacoma 2.7l the two outer cylinder were at 160 while the two inner were if i remember correctly 130 someone recomended marvel mystery oil in the gas tank does anyone else have a suggestion the engine has 202 thousand miles on it
  2. Sep 25, 2021 at 2:10 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    How much oil is it using? One quart in 3000 miles is normal.
  3. Sep 25, 2021 at 2:14 PM
    glidestreet
    Donald
    none
    about a third to a quart every few days
  4. Sep 25, 2021 at 2:19 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Probably needs valve stem seals.
  5. Sep 25, 2021 at 2:22 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Assuming 25 miles a day? Burning not leaking? That’s a lot of oil going through the cats. When is your next exhaust test?
  6. Sep 25, 2021 at 2:23 PM
    glidestreet
    Donald
    none
    someone told me rings or an engine but the engines are almost half what i paid for the truck
  7. Sep 25, 2021 at 2:24 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    My truck has almost 140K miles and was burning about a quart of oil every 3,500 miles, but I switched to 10W30 and it seems to have helped somewhat; I had a compression test sometime in 2020 and it came back normal...
  8. Sep 25, 2021 at 2:25 PM
    glidestreet
    Donald
    none
    i live in nh. they do not test exhaust
  9. Sep 25, 2021 at 2:29 PM
    PennSilverTaco
    Charlie
    Unless it is excessive, oil burning/consumption will not cause a vehicle to fail emissions testing, at least not here in Pennsylvania...
    Did New Hampshire ever have emissions testing? I thought they did at one point...?
  10. Sep 25, 2021 at 3:32 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Sounds like valve seals or rings to me with that much oil consumption
    Call LKQ. They are country wide
    I really can’t see a 2.7 being expensive
  11. Sep 25, 2021 at 7:45 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Rings or valve seals.
    Steer clear of the "cure in a bottle". At best the "fix" will be temporary.
    Key-Rei likes this.
  12. Sep 25, 2021 at 9:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I wouldn’t waste my money with any gas additives.
    My guess would be a rings. Did you happen to get wet vs dry compression #’s
  13. Sep 25, 2021 at 9:15 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Some gas additives do actually help clean injectors and such, (the owners manual recommends Chevron Techron) but not going to help with burning oil in this case.
    Project Farm did a video on Restore oil additive and did actually see some measurable gains in compression but ymmv.
    TnShooter likes this.
  14. Sep 25, 2021 at 9:26 PM
    TnShooter
    Deogee
    STOCK
    I agree. If you add anything, add it to the oil.
    I’m pretty sure the 2TR uses low tension rings.
    The rings can get stuck in the piston ring groove and not allow the ring to expand fully.
    It can’t hurt to try it, but I doubt it will help.
    That’s a good bit of psi difference.
