Oil Control Valve Location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brutalguyracing, Mar 31, 2013.
  1. Mar 31, 2013 at 3:36 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    looking for the location and any info on the oil control valve location on an 09 tacoma 4.0
    thanks....
  2. Mar 31, 2013 at 3:50 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    What is that ?
    Brett
  3. Mar 31, 2013 at 8:31 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  4. Mar 31, 2013 at 8:41 PM
    mardoqueo galindo
    mardoqueo galindo Well-Known Member
    marcos
    socal
    08 preruner
    toyota 20" wheels,borla double tip exaust,running boards,K&N air filter.
    no idea what you talking about
  5. Mar 31, 2013 at 8:44 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Regulates the flow to the VVTi system.
    I believe they are located toward the front of the heads just ahead of and slightly below the #1 and #2 intake runners. Manifold does not need to be removed, but it is tight.
    But I'm not 100%... I remember seeing a diagram pointing out an item in that area.
  6. Mar 31, 2013 at 9:03 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  7. Mar 31, 2013 at 10:07 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    gimmie a min and ill show u exactly where they are at. only thing u need to remove to get to them is the throttle body and possibly air intake
  8. Mar 31, 2013 at 10:09 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    u can see where they are located here. the two circles are what you are looking for. the pass side u can see the OCV. depending on which one u need, i might have it but wont be able to ship it until end of the month. Only reason i dont have my s/c on in this pic is becuase i removed it to get to the cams themselves.. so u dont need to remove the intake but like said before. its a tight fit. iw ould suggest either disconnecting the cam sensors connectors, or remove the cam sensors themselves.
  9. Mar 31, 2013 at 10:15 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    BassAckwards and knottyrope like this.
  10. Apr 1, 2013 at 4:34 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Just out of curiousity, how many miles did you guys have when these needed replacing?
  11. Apr 1, 2013 at 4:37 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Thanks I will check this out today
    And I'm assuming bank a is drivers side
  12. Apr 1, 2013 at 4:38 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    I have 96+k on truck now
  13. Apr 1, 2013 at 9:15 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    No bank a is passenger
    I didn't ever replace my occurs since that wasn't my problem. Just pulled them to check the ohms
  14. Apr 1, 2013 at 2:17 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    What are the ohms suppose to be
  15. Apr 1, 2013 at 2:20 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    6.9 to 7.9 Ω at 20°C (68°F)
    knottyrope likes this.
  16. Apr 1, 2013 at 2:24 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Thank u rep to u when I get off da beach
  17. Apr 1, 2013 at 2:25 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    also, if u can. put 12 volts to the ocv and make sure it actuates fast and doesnt stick
  18. Apr 1, 2013 at 2:42 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    will do might attempt this tomorrow
    i beat the crap out the truck today on and off road and i didnt notice anything different at all
    except for the poping and pinging of my cv's
    which is normal for me
  19. Jul 22, 2014 at 1:44 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    to revive an old thread... are these something that HAVE to be replaced or can they just be cleaned?
    I've got both P0012 and P0022 codes so I guessin I'd need to check both OCV's but I'm also at work and livin outa a hotel for the next two months so I don't wanna be tearin my truck apart too much in the parkin lot before I know exactly what I need to do
  20. Jul 26, 2014 at 8:56 PM
    Toyotamudbogs
    Toyotamudbogs Well-Known Member
    Devin
    White Springs , FL
    06 Tacoma 4x4, 4 door sr5
    Tintedwindows,Rockforfosgate amp 2 10" sub , fire dept radio,Rock sliders, Body Armer front Bumper, CB, 3'' EZ leveling kit, fog light mod, beep on lock mod, front duallys rigid led lights, rigid led flasher kit
    Mine is throwing a pending p0022
