Oil...conventional or synthetic
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4x2sst2001, Aug 31, 2019.
  1. Aug 31, 2019 at 7:35 AM
    4x2sst2001
    4x2sst2001 [OP] Member
    Jim
    4x2sst2001
    recently bought a 2001 4x2 owned by an 80 yr old guy for 10yrs in Mass I'm in NH...most of the trucks life has been down FL too till he shipped it up here,I mostly like buying from a private party,.....like some of these clowns that have a dealers license and sell a few vehicles on the side,I was concidering a 1st gen tundra,l asked if your a private party...sometimes they'll say yes but I sell a couple on the side,well I'm looking for something reliable I said,is this is reliable? He says "oh yes"...ok well how long have to had the truck?...his answer...3days...have a nice day pal I'm all set....so back to today my 2001 4x2 I'm doing my 1st oil change,if it had conventional oil in there which I don't know is it ok to put synthetic (5w 30) in?
    GQ7227 likes this.
  2. Aug 31, 2019 at 7:37 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes.
    4x2sst2001[OP] likes this.
  3. Aug 31, 2019 at 7:39 AM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    I would stick with dino or a blend.
  4. Aug 31, 2019 at 7:41 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I use synthetic in all my cars, including my 1995
  5. Aug 31, 2019 at 7:50 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    those Tacoma (and other) flippers are unreal, aren't they lol your post got a chuckle with those clowns and 3 days
    i wonder if that cash offer i got on mine at some random gas station this past week was from a flipper looking to trick a 50 per cent profit...
    <<< convential oil here since the first change at 1k miles
  6. Aug 31, 2019 at 8:07 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Conventional, blend, or synthetic, it doesnt matter in the older trucks. Napa has 5 quarts of Blend on sale for $12.99 right now. I did that cause Im a cheap bastard, and its Valvoline oil according to the back of the jug.
    GQ7227, CS_AR, ajm and 1 other person like this.
  7. Aug 31, 2019 at 10:06 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Yes, it is safe to switch to synthetic oil
    But there's one thing: Synthetic highlights worn out gaskets issues and because of that, you may see leaks appear. Since synthetic has smaller molecules than conventional oil, it can seep through little cracks and tears of worn out gaskets that conventional oil couldn't because of it's bigger molecules.
    So, the myth saying that synthetic causes leaks is false. It does not cause leaks, it just highlights gasket issues. Issues that would have eventually resulted in leaks anyway, even with conventional oil
    YotaTaco04 and GQ7227 like this.
  8. Aug 31, 2019 at 10:11 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You're in the northeast? Just conventional oil will do. The frame and body won't last long enough for synthetic to matter...
  9. Aug 31, 2019 at 10:44 AM
    4x2sst2001
    Jim
    4x2sst2001
    I'll hope for the best and use synthetic,truck has no rust..(FL 10yrs)...thanks
    GQ7227 likes this.
  10. Aug 31, 2019 at 10:47 AM
    4x2sst2001
    Jim
    4x2sst2001
    155k no leaks anywhere no rust
  11. Aug 31, 2019 at 12:04 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this is interesting info to me, thanks
    are you talking leaks in the oil pan and/or VCGs
    or the other varied seals, etc.
  12. Aug 31, 2019 at 12:59 PM
    onakat
    Canada
    2000 indestructaco!
    anything you can put oil into and that has gaskets or seals, so yes, oil pan, transfer case, differential, etc...
    Of course if your gasket is all good, it's not going to leak. It's only in case of old and worn out gaskets/seals. But old does not always means it is bad. When it is leaking is when it is bad, so no need to replace the gaskets everytime you do an oil change
    GQ7227[QUOTED] likes this.
  13. Aug 31, 2019 at 1:01 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    if you don't use AMSOIL or Royal Purple your engine will explode
  14. Aug 31, 2019 at 1:04 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There are no downsides to using synthetic. Conventional oil is fine too, but you need to change it more often.
  15. Aug 31, 2019 at 5:11 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I use synthetic in my new engines, however If conventional has been use, stick with it.
  16. Aug 31, 2019 at 5:24 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Use Oil.
    vern650 and BillsSR5 like this.
  17. Aug 31, 2019 at 6:03 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    But if you want it to last for a bazillion miles consider only OEM Toyota motor oil. They keep the really good stuff exclusively at the dealerships...:spending:
    GQ7227 and CS_AR like this.
  18. Aug 31, 2019 at 6:10 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    My Tacoma has been running synthetic oil since new and only has 72k miles
  19. Aug 31, 2019 at 6:19 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    If it were mine, I would run M1 5w30 High Mileage synthetic. It's got seal/gasket conditioners as well as a healthy additive pack and detergents. It's also on the heavier side of the 5w30 range with a viscosity of 12.7 vs M1 at 11 at 100°.
  20. Aug 31, 2019 at 9:09 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how did you know they have the very best stuff!
    they always top it off with a sprinkle of fairy dust
    and i always TRY to keep it under $30 or low $30s if at all possible, the $19.95 coupon days were always nice :cool:
