oil cooler leaking bad
Discussion in 'Technical Chat' started by BackwoodsTaco, Jan 11, 2013.
  1. Jan 11, 2013 at 6:55 PM
    BackwoodsTaco
    BackwoodsTaco [OP] Well-Known Member
    Paul
    Stokes, NC (Eastern NC)
    Radiant Red 01 DC, 4X4, SR5, Supercharged
    TRD Supercharger, URD 7th injector kit, TRS RetroFit, Deck Plate Mod, No Chime Mod, Fog Light Mod, CB/ashtray Mod, 2.5" Spacer Lift, 1.25" Lift Shackles, 4 Tab Light Bar From Eddie209
    I just got done installing my freshly rebuilt engine after a long 2 months:woot: and I was so happy that it was running that I was jumping up and down, hollering, the hole 9 yards until I looked under my truck to check for leaks and there was a bad oil leak so I scrambled to cut off my truck. I then took my drop light under my truck and found that my oil cooler was leaking I tightened it up because I thought maybe it was loose. Then I topped her back off with oil and cranked my truck and slid under there and sure enough it was coming form the oil cooler. So do you guys think it is the gasket that needs to be changed or do I need a new oil cooler all together
  2. Jan 11, 2013 at 6:58 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    have a PICTURE?
  3. Jan 11, 2013 at 7:03 PM
    BackwoodsTaco
    Paul
    No but I just took off the oil cooler and I found that I didn't put a new gasket up there when I installed it :facepalm:
  4. Nov 14, 2013 at 7:50 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    When you took the oil cooler off was there anything special you have to look out for?
    My cooler has a very slight leak/ seepage of oil comming from the side that mounts to the engine or atleast it looks like it does. I've seen a diagram and I think there is a gasket back there. When and if I take it apart, can I just unbolt and place the new gasket in? Or is there more to it than meets the eye?
    Also, should I expect to lose all the oil when I unbolt the cooler? I'm due for an oil change so I will probably do it at the same time.
    Thanks!
  5. Nov 15, 2013 at 4:43 AM
    BackwoodsTaco
    Paul
    The only thing to it is the bolt in the center and an o-ring. It's pretty simple but be careful with the o-ring, make sure you get it lined up in the ridge before you tighten the bolt or you will pinch it. I would buy two just in case you mess one up. I belive they're only 2-3 bucks at the stealership. It can be a PITA tryin to get the o-ring to stay put but just take your time and you should be good. I've got the Toyota service manual on my computer, I can email you a copy of it if you need it
  6. Nov 15, 2013 at 5:34 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    Rincon, GA
    08 TRD Off-road
    Could you email that to me? I don't need it know but it never hurts to have all the info one can get. Thanks!
  7. Nov 16, 2013 at 8:08 AM
    Mainmoe02
    Moe
    Austin, Texas
    PM sent regarding the servcice manual
    Thanks Paul
