oil cooler location on 02 TRD
Discussion in '1st Gen. Tacomas (1995-2004)' started by RockyTacoma, Mar 14, 2010.
  1. Mar 14, 2010 at 4:36 PM
    RockyTacoma
    RockyTacoma [OP] Well-Known Member
    Dojo
    colorado
    2002 tacoma trd
    stock
    I have 2002 TRD V6. my truck have rear hitch, so im assuming it has tow package. does that mean my truck has oil cooler?....where is this oil cooler located. i checked the oil filer, didnt see anything
  2. Mar 14, 2010 at 4:59 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    A Class III hitch was included in the factory Towing Package, but hitches were also available as accessories. Having a hitch doesn't necessarily mean you have the Tow Package.
    The transmission oil cooler was included in the Towing Package only on automatics. Is your Taco an automatic?
  3. Mar 14, 2010 at 5:06 PM
    RockyTacoma
    Dojo
    colorado
    2002 tacoma trd
    stock
    its 5 spd, i do see like 2 radiator looking things up front
  4. Mar 14, 2010 at 5:09 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    1st gens dont have a tow package if im not mistaken=no oil cooler
    i could be wrong though
  5. Mar 14, 2010 at 5:17 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    open your hood and look at your fan behind it should be either the color orange or green. orange means no tow package,green means tow package. so im told anyway
  6. Mar 14, 2010 at 5:19 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    ones a rad the other is for air conditioning
  7. Mar 14, 2010 at 5:20 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    The second radiator should be for your AC
  8. Mar 14, 2010 at 5:22 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Is one of them a sort of 'mini-radiator' mounted next to the radiator? If so, that sounds like an aftermarket cooler of some sort.
    There's no such thing as a factory transmission oil cooler on 1995.5 - 2004 Tacomas with manual transmissions.
  9. Mar 14, 2010 at 5:25 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Oh - he was referring to the A/C condenser? :facepalm:
  10. Mar 14, 2010 at 6:56 PM
    RockyTacoma
    Dojo
    colorado
    2002 tacoma trd
    stock
    ...yes, but i was wondering if my truck has factory oil cooler, i have manual shift
  11. Mar 14, 2010 at 9:27 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    If you mean a factory *engine* oil cooler - yes ... All 2001 - 2004 5VZ's have a standard oil cooler unit. However, it's not a 'mini-radiator' up front. It's a round thingie aft of the oil filter.
  12. Mar 14, 2010 at 10:07 PM
    blackwidow2009
    blackwidow2009 Well-Known Member
    Brian
    Cleveland
    09 Access Cab 4X4 TRD w/ SR5
    2.5" front lift Daystar coilover spacer. 2.5" rear lift add-a-leaf N-Fab wheel to wheel nerf/step bar Polished Stainless Leer cap from my 2000 Tacoma --- It does fit; don't let them lie to you
    Look under your hood...look at the shaft that you fan is on. Look for the colour that it is. The 1st. gen had different colours for the different load/towing caps. If it is "millitary green" your truck is rated for 3500lbs payload/350lbs tounge. If the shaft is "hot pink/magenta" then it is rated for 5000lbs payload/500 tounge.
    I used to have a 2000 extra cab 4X4 TRD SR5 and it was rated at 5000/500lbs, BUT it did not come with a hitch!!! At the same time, my cousin's 2002 extra cab 4X4 TRD SR5 was rated for only 3500/350lbs. and it DID come with a hitch!!!
    So, the factory hitch is NOT an indicator of it's rateing. You need to look at the cooling fan shaft's colour. Sounds stupid I know, but that really is the way to tell.
    If it is PINK/MAGENTA then it DOES have the bigger trans cooler. I do not know if it has an additional oil cooler though. I do remember that when I bought mine I explisitly made sure mine was the 5000/500lbs one that CAN tow the increased amount. So, my thinking is that if it was rated for more weight, they put whatever extra coolering devices in that was needed.
  13. Mar 15, 2010 at 6:18 PM
    RockyTacoma
    Dojo
    colorado
    2002 tacoma trd
    stock
    my fan shaft is orange i color
  14. Mar 15, 2010 at 6:32 PM
    cmf21
    cmf21 Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    I think you have green and orange backwords.
  15. Mar 16, 2010 at 1:33 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    yep
  16. Mar 16, 2010 at 1:40 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    then your truck doesnt come equipped with the tow package. it is possible though to make your truck have the tow package by changing out the orange fan clutch for the green fan clutch, adding a transmission cooler,and of course the hitch. thats for the automatics though,not sure about the manual trannys
  17. Mar 16, 2010 at 7:32 PM
    blackwidow2009
    Brian
    Cleveland
    Yeah, I proably do...need to look at the book again...lol...sorry if I got it wrong...I'll double check
