Oil Diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTLTaco, Dec 20, 2011.
  1. Dec 20, 2011 at 10:20 AM
    MTLTaco
    MTLTaco [OP] Well-Known Member
    Montreal
    09 Double Cab TRD
    I noticed that my truck has some oil visible that looks to be leaking from the bolt on the rear diff. This is visible when you look under the truck from the back. Is this common? Truck has 78500KM/49000Miles
    Thanks guys for any input
  2. Dec 20, 2011 at 10:28 AM
    95Yota4x4
    95Yota4x4 -FURY FROM THE SKY
    J.D.
    Houston, Tx
    Black 95 Tacoma, reg cab, 2.7L 4 cyl, 4x4
    4" lift
    Might be time to replace rear diff gasket. Prolly around $5-$10 at local auto parts store depending on your model. Make sure you get some gasket sealer to go with it. Not a hard DIY. Check your manufacturers manual to see which type of oil to get to replace the stuff you drain out.
  3. Dec 20, 2011 at 10:50 AM
    MTLTaco
    Montreal
    09 Double Cab TRD
    Already? With less than 50000miles?
  4. Dec 20, 2011 at 12:26 PM
    fadippides
    fadippides Well-Known Member
    NEPA
    12 TRD Off Road
    Would that be covered by the powertrain warranty?
  5. Dec 20, 2011 at 12:35 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    The dealer is going to cover it. Just wondering if this is common especially with that mileage.
