Oil Dip Stick Stuck ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, May 26, 2024.
  1. May 26, 2024 at 9:25 AM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    My oil dip stick is stuck - that sucks - no matter how hard I pull on it by hand it doesn't come out - any suggestions ? I've never run into this - is it safe to gab it with pliers and pull hard or will the plastic loop separate ? Should I soak it in silicone or BP Blaster ? Any suggestions/links appreciated - I just don't want to destroy it and have the metal part of the dip stick irretrievable from the tube.
  2. May 26, 2024 at 9:45 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  3. May 26, 2024 at 10:09 AM
    george3
    New Jersey
    OffroadToy[QUOTED] likes this.
  4. May 26, 2024 at 12:12 PM
    OffroadToy
    Yep, had a fishing trip planned for monday until i found out what weekend this is. As far as getting that info just google the words... oil dip stick stuck tacoma world.
  5. May 26, 2024 at 3:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did you try twisting and pulling?
    I've never seen a dipstick get stuck in the tube.
    Then again I never saw an oil pan get a hole rusted in it either and I'm oldish...
    Robnik likes this.
  6. May 26, 2024 at 3:53 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    O-ring probably stuck to the tube opening. Twist the handle first then pull.
    Robnik likes this.
  7. May 26, 2024 at 4:06 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Truth be told, the dipstick on my 2014 Tacoma did the exact same thing. I did the "twist and pull" thing to remove it. Before I put it back in, I applied a bit of oil to it where it seals to the dipstick tube.
    And as you know, I'm oldish too. :rofl:
    Jimmyh[QUOTED] likes this.
  8. May 26, 2024 at 4:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I always have done the "Twist and Pull" method on the dip stick.
    Robnik likes this.
  9. May 26, 2024 at 4:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'm older than both you clowns and haven't gotten my dipstick stuck yet........ :p:D
  10. May 26, 2024 at 4:30 PM
    Too Stroked
    Tom
    At my age, I'm just glad my dipstick still works. :rolleyes:
    Robnik, TXpro4X4 and Jimmyh like this.
  11. May 26, 2024 at 4:42 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Good practice for various rubber parts in general, hoses, ignition coil boots, etc. Learned this trick from Briansmobile1 Youtube channel.
  12. May 26, 2024 at 4:52 PM
    OffroadToy
    the twist and pull...
    Robnik, 08TacoTrD and Jimmyh like this.
  13. May 26, 2024 at 7:40 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Yea, thinking of pushing.....lol
    Robnik likes this.
  14. May 26, 2024 at 9:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pull harder
    Robnik likes this.
  15. May 26, 2024 at 9:26 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    This is still going on, lol. Put a screwdriver through the ring, twist & pull on the screwdriver.
    Apparently doesn't check oil level much. The metal won't separate from the plastic. Plastic & O-ring is what's stuck.
    :facepalm:
  16. May 27, 2024 at 4:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    #savethedipsticks
    #dipsticksmatter
    Naturally I'm referring to transmission dipsticks here. Glad my '13 has one, makes life easier!
    Jimmyh and Robnik like this.
  17. May 27, 2024 at 4:43 AM
    Robnik
    Rob
    Greenacres, Florida
    I know, Bill. Sealed tranny, WTF. I like to physically see what my fluid levels are at.
    Have a great Memorial Day fella's :oldglory:
    Jimmyh likes this.
  18. May 27, 2024 at 5:19 AM
    Goldielocks
    Goldielocks Well-Known Member
    Nine times out of ten I've watched others try to 'unstick' or remove fasteners by using more force. (Kind of like losing your temper) Here's what has worked for me: On anything with plastic, spray a small amount of CRC electronic lubricant/cleaner and using a heat gun briefly WARM the stuck piece. Attempt to remove, wait for cool down, repeat. On metal stuck pieces, spray a small amount of WD40, WARM briefly with heat gun, let cool and attempt to remove. Most often the thermal expansion and contraction combined with the penetrant brings success!
  19. Oct 7, 2024 at 12:45 PM
    JohnTstratfordCT
    JohnTstratfordCT New Member
    2013 Tacoma 150k
    new engine!
    Hey I just went thru the 'stuck dipstick syndrome' and I got it unstuck without breaking it, thank God. I just have some insights to offer.... The guide tube is very long and part of it is almost horizontal. Oil can collect in there. Also, it runs just underneath the exhaust manifold, so the bit of oil in the tube is 'cooking' a bit. Mine showed dried-up tar-like oil just above the oil level marks... so get some liquid wrench in there if you can, and pull and pray. If it were to break, you could still drive it to a shop. Clean off the whole stick and bring it in and out more often. Not a super great design.
  20. Oct 7, 2024 at 12:59 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I know this is an older thread but Ill add this happened to me once on a Dodge Charger I used to have. The pull ring snapped right off.
    Was able to carefully drill a hole in the plastic nub left behind in the tube. Then thread in a small wood screw and pull the whole thing out with pliers. Food for thought incase the ol 'twist and pull' doesn't work for someone in the future
