Oil Dipstick Level
Discussion in '2nd Gen. Tacomas (2005-2015)' started by this_is_nascar, Mar 18, 2020.
  1. Mar 20, 2020 at 2:16 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Take it to someone to have it done...
  2. Mar 21, 2020 at 9:09 AM
    this_is_nascar
    this_is_nascar [OP] Well-Known Member
    Gloucester City, NJ
    2007 TRD Off-Road
    Mission accomplished. Thanks to everyone that provided helpful hints, tricks and procedures. I really do appreciate the support and encouragement. I was able to complete the oil/oil filter change and everything seems to be fine. For all the dick comments, what can I can. It's the Internet and there will always be keyboard warriors. Take care everyone and stay safe.
    Muddinfun likes this.
  3. Mar 21, 2020 at 11:59 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Nah, I have those Dorman light blue poly-something washers on all my Toyota products; got a bag of 25 or so about 15 years ago; replace them about every 3-5 oil changes. Never had a leak. Have about 6 left.
  4. Mar 21, 2020 at 12:30 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Using this method, you will always end up slightly over-filling the engine. That's because if you check the oil immediately after shutting an engine off, not all of the oil will have drained back into the oil pan from the upper reaches of the engine. This doesn't generally make for a significant over-filling, but you will be at least slightly over-filled. Truly over-filling and engine can lead to the crank throws thrashing around in the oil, causing foaming and all sorts of oil related issues.
    cryptolime likes this.
  5. Mar 21, 2020 at 12:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That yellow dipstick is for your transmission oil level, not your engine. There is no oil level dipstick and you have to check it via a fill plug on the side of the engine block.
  6. Mar 21, 2020 at 3:06 PM
    c212
    c212 Well-Known Member
    I use Dormans as well: https://www.dormanproducts.com/p-370-095-156.aspx I get them from Rockauto. They look identical to what I used to get from the Toyota parts counter.
    But I change them every time. I tried using one more than once but had a bear of a time getting it off the bolt, so I quit doing that.
  7. Mar 21, 2020 at 3:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You have it backwards.
    Dipstick is for the engine oil. The transmission for the 6 cylinder has no dip stick.
  8. Mar 21, 2020 at 3:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You are killing my sarcasm here Jimmy. How am I supposed to troll the troll if you are over here posting the factual information? :smack::laugh:
  9. Mar 21, 2020 at 3:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I thought your comment was out of character...................:anonymous:
    12TRDTacoma[QUOTED] likes this.
  10. Mar 21, 2020 at 3:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If it sounds too odd coming from me it is always an attempt at a weekend troll of the weekend trolls. :cheers:
  11. Mar 21, 2020 at 4:01 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I have #66301; they are a ribbed design that, I’ve always believed, deflect for pan imperfections to provide a leak free application. They are now sold in a three pack only, but I see a vendor on Amazon selling a similar design - bag of 50 for $14; added them to my cart. They refernece the Dorman part #; probably from same Chinese manufacturer. Buy Auto Supply BAS03550.
    https://www.dormanproducts.com/p-16161-66301.aspx?origin=keyword
    https://www.buyautosupply.com/categories/drain-plugs-gaskets.html#
    Edit - found Dorman pt# of 25 pack - 097-116. Why such different part #?
    https://www.dormanproducts.com/p-32065-097-116.aspx?origin=keyword
  12. Mar 21, 2020 at 4:50 PM
    c212
    That's interesting. I came across the Dorman PN I use by letting Rockauto lead me there with its menu system. For me it was Toyota -> 2013 -> Tacoma -> 2.7L -> Engine -> Oil Drain Plug Gasket. I picked the one that looked closest to the OEM gaskets in terms of appearance and construction, and that just happened to be the Dorman. ¯\_(ツ)_/¯
  13. Mar 21, 2020 at 4:55 PM
    Waasheem
    Waasheem
    2007 xrunner
    I recall reading here of oil starvation issues with thr 4.0 if it isn't filled to the upper dot. Most every other engine can be considered good between the upper and lower marks. I know of one transmission on a machine I work on, it has to be filled to the mark just above the bottom mark, higher it comes out on top.
    As others stated, fill to 1/2 qt less than it says it needs, start, idiot light goes out, stop, then a pause is necessary to allow oil to drain down before checking the dip stick. Use the time to start putting stuff away, look under for leaks. I'd say 2 minutes is plenty pause, to each their own. Then check the dipstick, add if needed, rinse, repeat.
    I could be wrong here, I think it was 5qt with a stubby filter, NOT recommended. 5.5qt with a standard longer filter on the 4.0.
    mjd729 and EnonEye like this.
