Oil dipstick on 2020 Tacoma SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Grehound27, Dec 4, 2020.
  1. Dec 4, 2020 at 5:58 AM
    Grehound27
    Grehound27 [OP] New Member
    Dave
    2020 Toyota Tacoma SR5
    None
    The dipstick on my 2020 Tacoma is difficult to insert. Pulls out fine but really a struggle to reinsert. Any thoughts??
    Thanks in advance.
    Dave
  2. Dec 4, 2020 at 6:13 AM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    My 2017 is the same, but it gets better the more you use it. It also has a way it wants to go in and if you force it, well, it gets angry.
    PS...prepare to be awarded the first "Friday" post.
  3. Dec 4, 2020 at 6:16 AM
    Grehound27
    Dave
    None
    Thank you Sir & thanks for your service.
  4. Dec 4, 2020 at 6:19 AM
    OuchIDied
    OuchIDied Well-Known Member
    2021 Silver Sky Tacoma Off-Road
    Note the bend in the tube and make sure the flat part of the dipstick is the part that goes along the bend. Align it and then insert. It can be finicky.
    tonered and Grehound27[OP] like this.
  5. Dec 4, 2020 at 6:22 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  6. Dec 4, 2020 at 6:36 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    The sharp edges on the end can also make it more difficult and scrap off metal from the tube giving the appearance of metal shavings in your oil. A minute with sandpaper solves both those problems.
  7. Dec 4, 2020 at 9:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Also, roughing up the faces makes it easier to read, esp just after an oil change.
    Anton338 likes this.
  8. Dec 4, 2020 at 9:55 AM
    Grehound27
    Dave
    None
    Thanks.
    tonered likes this.
