Oil dipstick problem or too much oil in engine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoNumber6, Oct 27, 2015.
  1. Oct 27, 2015 at 9:54 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Keep in mind that there are good techs and bad techs at any place. Lube/maintenance techs are usually the bottom of the barrel and is a starting point for most. Supposedly they are "Toyota trained technicians" but one dealership by my house have some of their service bay that can be visible from the waiting area. I've watched some of the techs figure out which bolts were needed to be taken out in order to get to the oil cartridge canister on a prius and a 5th gen 4runner. I also saw another tech know exactly what he was doing. Checked air pressure, brakes and even checked all the lights were functional. He even wiped down the top of the engine/cover.
  2. Oct 27, 2015 at 10:13 AM
    TacoNumber6
    TacoNumber6 [OP] 6 TIMES A CHARM
    like I said, my main concern was any possible damage that could occur, I was always told too much oil is bad for motors, but some people are saying this is fairly common with these motors
  3. Oct 27, 2015 at 10:17 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Too much oil in the crankcase will aerate and can damage the main bearings.
  4. Oct 27, 2015 at 10:22 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    you have some wiggle room before boom... :bananadead:
  5. Oct 27, 2015 at 10:23 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I never changed oil in the prius so I was assuming there were bolts just like on the 5th gen as part of the plastic and skid plate underneath needs to be removed to get to the oil cartridge canister.
    For those who have not had the pleasure of changing a cartridge filter, there's a tad bit more steps involved.
    DoorDing likes this.
  6. Oct 27, 2015 at 10:24 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That's why I said check it with the engine running.
    There is room and that isn't near enough to be concerned.
  7. Oct 27, 2015 at 11:45 AM
    TacoNumber6
  8. Oct 27, 2015 at 1:25 PM
    vtdog
    vtdog Well-Known Member
    NH
    More than likely the tech dialed in the correct amount of oil for the refill, but was rushed and did not let the dirty oil fully drain out. It is a common problem with fast lube joints, but if the dealer tech gets paid by the job the same problem would apply.
  9. Oct 27, 2015 at 1:47 PM
    devkurf
    devkurf Member at Large
    midwest
    Thats whats scary, you had no idea WTF they were doing, and neither did they.
    taco_marty likes this.
  10. Oct 27, 2015 at 1:57 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Took my 2015 for the first oil change and the mechanic must have had a big ass belt buckle on, He scratched and gouged my grill, took four more trips back to the dealer for them to get the correct part to replace it.
  11. Oct 27, 2015 at 2:52 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    1. NEVER TAKE YOUR TACO TO THE DEALER
    2. CHANGE YOUR OIL AND TIRES
    3. WINNING
  12. Oct 27, 2015 at 3:28 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Crazy
  13. Oct 27, 2015 at 4:15 PM
    Fury
    Fury Well-Known Member
    I run mine right at the full mark. I have done all my own changes (7 so far) and it takes 4.9 to 5.0 liters with a filter change. The book says 5.2 but this is only a reference - the dipstick should be the last word.
    FYI - unlike most dipsticks, our 4.0 is 1.5 liters between add and full. Most are 1.0 liter. You could add as little as 3.5 and still be at the add (not that I recommend it).
    I add 4.5, change the filter, start, turn off, wait, adjust using the dipstick.
    OP that is a little higher than I personally could live with if I did it myself. I would dump a little. I agree with others that this is probably not high enough for the crank to hit the oil and froth it up which could hurt the plain bearings, though.
    a400ryan likes this.
  14. Oct 27, 2015 at 4:50 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Some think the dip stick is off but if that was the case you'd think in 10 years toyota would addressed it. I just use 5qts... looks perfect on the dip stick and never had an issue. One thing for sure... it's always better to be a hair on the low side than high. The chiltons and toyota manuals both give the same amount (5.5) but chiltons mentions that it's reference only... you add as necessary to bring to the appropriate level. Same thing for gear oil capacities.
  15. Oct 27, 2015 at 5:03 PM
    #35
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The dip stick is never that clearly marked for me.
  16. Oct 27, 2015 at 7:16 PM
    #36
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Put in first gear, accelerate up to max speed for that gear......hold it for 1 1/2 hours. The level should drop.
  17. Oct 28, 2015 at 9:46 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not better to be on the low side if the owner's engine has the shallow upper/lower oil pans. Spun bearing and rod knock will be in the certain future.
  18. Oct 28, 2015 at 12:42 PM
    #38
    TacoNumber6
    you would think....
  19. Oct 28, 2015 at 1:52 PM
    #39
    OffroadToy
    sorry, i should have been more clear... a hair under the full mark on the dip stick
  20. Oct 28, 2015 at 2:44 PM
    #40
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    If it starts leaking oil on your crank seal Area (arrow in picture) than you'll know that overfilling with too much oil could have caused seal damage.
