Oil dipstick stuck!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hossdawson, Dec 9, 2021.
  1. Dec 9, 2021 at 9:30 AM
    Hossdawson
    Hossdawson [OP] Well-Known Member
    Hoss
    Harrisburg, Pa
    2025 TRD Sport Underground
    Hi
    Anyone else have their oil dipstick get stuck on their 2021? I finally got mine out but I was afraid that it was gonna break. I looked like there was some corrosion at the top causing it to stick. I cleaned it as best as I could and lubed the o-ring. It still fits tight but at least I can get it out.
    Thanks
    Hoss
  2. Dec 9, 2021 at 9:33 AM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Oh, ok, I understand.
    Stop taking so much Viagra.
    DNguyen1033, SR-71A and vivid02 like this.
  3. Dec 9, 2021 at 9:38 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Was this the first time you tried to pull it out and check your oil level? If so, probably just tight from the factory and sitting there untouched since it was built. Like most mechanical stuff, it should loosen up and operate as it should the more you use it.
  4. Dec 9, 2021 at 9:39 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    I smell Oneshort's return.
  5. Dec 9, 2021 at 9:41 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    twist and pull?
  6. Dec 9, 2021 at 9:49 AM
    eon_blue
    Azusa, CA
    Was probably that corrosion you found, just make a point to check it more regularly to keep it from happening.
    vivid02 and BudFriendguy like this.
  7. Dec 9, 2021 at 10:02 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Not stuck but mine will only go in the tube in one orientation. If you twist it 180*, it won't go all the way in. It would seem I have a fickle dipstick. o_O
  8. Dec 9, 2021 at 10:57 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Corrosion on a 21?
  9. Dec 9, 2021 at 2:21 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Don't ya hate that!
  10. Dec 16, 2021 at 10:16 AM
    Ksinger4
    Ksinger4 Well-Known Member
    Dayton, OH
    2019 DCSB TRD Off Road
    2012 DCSB TRD Off Road Wrecked :(
    I recently bought a '19 and just changed the oil for the first time. I cant get the dipstick out! It feels like it's jammed from the bottom somehow, the head rotates freely (not corroded) and i can hear and feel the steel part twisting in the tube. So I know at least the first few inches are free. Any ideas??
  11. Dec 16, 2021 at 12:33 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Lube the o ring on the dip stick if there is one…that’s what she said.
  12. Dec 16, 2021 at 1:23 PM
    Ksinger4
    Dayton, OH
    haha - yeah i had a hard time with word choice on this one.
    It's not the o-ring that's causing it, the head is loose, i can move it around.
