Oil Dipstick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glocker23, May 23, 2012.
  1. May 23, 2012 at 6:37 PM
    Glocker23
    Glocker23 [OP] Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    Ok Here is a wierd one. This is my first toyota. But how the hell do you guys check the oil when there is no hash marks or any marks for that matter on the dip stick.
    It almost looks like in the following pictures, a piece was there but isnt there anymore
  2. May 23, 2012 at 6:40 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Seriously? Min and max marks - what else you need?
  3. May 23, 2012 at 6:40 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    There are threads on here about the dip stick. I can't seem to get a decent reading on mine. It sucks.
  4. May 23, 2012 at 6:42 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Take some 80 grit sand paper and rough it up between the marks. Be sure to wipe off with a clean rag before putting it back in.
  5. May 23, 2012 at 6:42 PM
    medic2230
    Murph
    Bama! Roll Tide
    The taco has a dip stick? :rolleyes:
  6. May 23, 2012 at 6:42 PM
    Glocker23
    CT
    2012 DCSB Sport
    Sorry bro If thats all it is then ok. All my past chevys, oldsmobiles, ford, mazdas all had has marks of some kind. looking at those dimpals on the end it looks like something may have fallen off.
  7. May 23, 2012 at 6:44 PM
    medic2230
    Murph
    Bama! Roll Tide
    Nope, that's how it's suppose to be. They use the KISS method. :D
  8. May 23, 2012 at 6:44 PM
    Glocker23
    CT
    2012 DCSB Sport
    cool I may do that Thanks
  9. May 23, 2012 at 6:44 PM
    Polymerhead
    Missouri
    Yeah. that's all it is. Good luck getting a clean reading though. Mine is usually coated w/oil 3" above the max line. Some folks have reported good luck checking first thing in the morning when it's all settled out.
  10. May 23, 2012 at 6:48 PM
    blackpearl11
    blackpearl11 Well-Known Member
    2010 tacoma
    sheeew! glad yours is the same way. I was worried I had too much oil in the truck. Its like everyone said, this dipstick sucks at giving you a reading
  11. May 23, 2012 at 7:06 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Those are min/max marks. The way almost all of Toyota's engine oil dipsticks are. I have no problem checking the oil level of any 1GR or any other motor for that matter.
    Mind you, I do it everyday all day and know where I'm looking (Especially for those that have the residual that goes above the MAX mark.
  12. May 23, 2012 at 7:07 PM
    myname150
    myname150 Well-Known Member
    x2
    i've read somewhere on tw that usually the best reading is the first time you pull the oil dipstick out. after that the dipstick tends to get coated oil well above the max dot leading to inaccurate readings.
  13. May 23, 2012 at 7:36 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Read between the dimples.
  14. May 23, 2012 at 7:48 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Easy to read when cold. Check before you start it in the morning.
  15. May 23, 2012 at 8:33 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I check mine first thing in the morning before it's been started. Pull the stick out, read it, put it back. Wipe it off and retry and it reads weird.
    FYI my owner's manual says it's a quart and a half low when at the lower dimple. I have never added oil, so can't really say.
  16. May 23, 2012 at 8:42 PM
    1GR
    Scott
    BC, Canada
    Well the only acceptable reading is MAX. I was just stating that I know where to tell the difference whether it is residual oil from the dipstick tube, or the actual oil level reading.
  17. May 24, 2012 at 12:42 AM
    Bajones
    Bajones Well-Known Member
    Considering the dipstick is accurate, what does say... a half full reading relate to? Would this be a quart down, 2.5 quarts down? I ask this because I want to know how much oil to put in when I don't get a full reading.
  18. May 24, 2012 at 12:49 AM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Pull dip stick out, wipe down, stick back in, spin 1/4 turn, spin back 1/4 turn to original position, pull out and look at the line and dimples. Check while cold.
  19. May 24, 2012 at 12:51 AM
    05sctaco
    Ken
    Santa Cruz
    pour 1/2 quart at a time to top off to full. Oil expands and contracts to temperature, and also if you ran the engine it's sucked up and spit around all over inside the engine.
  20. May 24, 2012 at 8:10 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've tried scuffing, sanding, and fileing it and still had trouble getting a good reading. Here's what works...
    Remove the dip stick, wipe it off, then wait 20 minutes before taking the reading. What this does is it gives the oil time to drain back down the tube after the dip stick was removed. You'll be amazed how good a reading this produces...works everytime!! :)
