Oil Dipstick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glocker23, May 23, 2012.
  1. May 24, 2012 at 8:14 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I believe the distance between the 2 marks on the dip stick equals one quart.
  2. May 24, 2012 at 8:26 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    from the manual...
    The approximate quantity of oil needed to
    raise the level between low and full on the
    dipstick is indicated as follows:
    2.7 L 4−cylinder (2TR−FE) engine
    1.3 L (1.4 qt., 1.1 Imp.qt.)
    4.0 L V6 (1GR−FE) engine
    1.5 L (1.6 qt., 1.3 Imp.qt.)
  3. May 24, 2012 at 9:37 AM
    Bajones
    Bajones Well-Known Member
    Thanks didn't think the manual would have that!
  4. May 24, 2012 at 4:12 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Check Oil? Daily?
    WTF? I check mine once a month if that and its always fine. Don't leak nor smoke so you aren't using any.
    :sandwich: tuna
  5. May 24, 2012 at 4:38 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    My 2006 Taco was always reading way over full and I took it back to the stealership, who was doing the first 4 changes for "free".... The first change, I checked it....it was overfull.... they said they put in the right amount...don't worry.... next time, same shit........OK.... finally I did my own oil change and the level was "spot on"... all I did was put the correct amount of oil into the truck.... It's been right on the mark ever since....
    The stupid dealer was overfilling my Taco.... Stupid bastards...!!
    They are total F--ups.... can't even put the right amount of oil into a truck...
    Over
