Oil dipstick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoOwner?, Jan 7, 2010.
  1. Aug 20, 2016 at 11:54 PM
    Jaryox
    Jaryox Member
    James
    2001 White Tacoma TRD 4X4
    Stock w/ Moonroof
    Hate being that guy to revive an old thread but just did an oil change for my first time on my 2001 3.4 automatic and used the recommended 5.5 I'm way over filled. I can't figure out why, I drained 3-3.5qts out (which was spot on for the dipstick). Also I'm using Mobil 1 5w30 high miles full synthetic. Anyways if it was overfilled and nothing felt wrong I wouldn't post here, but after the oil change I drove to the store and back (10 mins round trip) and twice had this feeling of not being in gear when i first try to accelerate from stopped. I would let up and it then it would go just fine but the truck also felt different. It felt smoother but almost sluggish or heavy through the gears, I tried to drive gingerly so I wouldn't cause as little damage as possible.
  2. Aug 21, 2016 at 12:10 AM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Me thinks you drained your transmission and added all the new oil to your engine.
  3. Aug 21, 2016 at 12:50 AM
    Jaryox
    Jaryox Member
    James
    Stock w/ Moonroof
    If I did.. Send me back to grade school..
  4. Aug 21, 2016 at 12:53 AM
    Jaryox
    Jaryox Member
    James
    Stock w/ Moonroof
    Oh my god you might be right.
    jpmorrisvb likes this.
  5. Aug 21, 2016 at 3:56 AM
    Clearwater Bill
    Billy
    Largo Florida
  6. Aug 21, 2016 at 4:18 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Oh my god! Not again.
    WTF People.
  7. Aug 21, 2016 at 5:23 AM
    Jaryox
    Jaryox Member
    James
    Stock w/ Moonroof
    In all fairness it is an easy mistake especially if your just trying to get it done quick. I went back to look and sure enough.. The oil pan is pretty hidden.. With only driven under 2 miles without a/t fluid I should be fine, correct? Also my dash has lights for a/t pressure and temp I believe, why weren't these tripped?
  8. Aug 21, 2016 at 11:36 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Try and sand the dipstick as suggested, if that doesn't work, spray paint the end if the stick white. I've done this and it works perfectly.
  9. Aug 21, 2016 at 2:10 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    It is an easy mistake but remember... engine oil drains from the engine . If your laying under the truck without a engine over your head chances are your in the wrong spot.
    spitdog, jpmorrisvb and Avsfreak18 like this.
  10. Aug 21, 2016 at 4:11 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I use a Fumoto valve so I don't confuse the two. I also send in a sample once a year to Blackstone having the valve makes it easier, and a lot less messier, to draw a sample. Just a thought...
  11. Aug 21, 2016 at 4:13 PM
    DrFunker
    DrFunker Well-Known Member
    I has been a while though. There was a time there that it averaged 2 per week.
  12. Aug 21, 2016 at 5:08 PM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    you may have to take that somewhere for some tranny fluid. You might have someone tow you. Make sure you put the right stuff in the right place. Oh don't forget to drain some of that oil. Sorry that happened Bud.
  13. Aug 22, 2016 at 4:12 AM
    Clearwater Bill
    Billy
    Largo Florida
    Don't think so. If there is, pictures please?
    'Cause they don't exist? You're lucky your trans even has a dipstick. Many newer vehicles don't.
    Very likely.
    Do not drive the vehicle till you get the excess oil out, and the trans refilled.
    There is good news though. I'd wager you'll never make the same mistake again. :thumbsup:
  14. Oct 29, 2016 at 10:01 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I just chescked my oil this morning and it looked way over filled. Drained out 5quarts though. Re filled oil and you can see it's a bit easier to read but there's still splatter on the dip stick. I thought I had blown a head gasket or something.
  15. Oct 30, 2016 at 1:39 PM
    #35
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    When I have the time, what I do is :
    1. Remove dipstick, wipe off, and wait 30 minutes (I like to do it after it sits overnite)
    2. Then, re-insert dipstick and measure the level.
    This allows the tube to drain.
    BrookTrout likes this.
  16. Apr 26, 2018 at 12:29 PM
    #36
    Snatchell
    Snatchell New Member
    2005 Tacoma Double Cab 4x4
    I had had troubles seeing the oil on my dipstick too. I scuffed it up with emery cloth today - wiped it off good and checked the oil and I could clearly see the oil line. Quick fix - works great - took about 3 minutes total. :)
    bijick and NAAC3TACO like this.
