Oil Dirty Front Differential @26k miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eltacosancho, Apr 11, 2023.
  1. Apr 11, 2023 at 9:52 AM
    eltacosancho
    eltacosancho [OP] Member
    Pat
    North Dakota
    2021 Grey Tacoma TRD OFF RD
    So I did my differential (front/back) and transfer case service myself @ 26k miles on my 2021 Tacoma TRD OFR I bought it new with 6 miles.
    I noticed my front diff was dirty and sludgy no metal shavings though. Anyone experience anything similar? Could it be the original diff oil is just shit or maybe it heats up quicker because it’s less volume of oil? TIA
  2. Apr 11, 2023 at 10:14 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The front looked worse than the rear? If not, it is normal that it look dirty even though the front is not used as much as the rear.
    eltacosancho[OP] likes this.
  3. Apr 11, 2023 at 10:15 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    The front would look clumpier as it’s not used as much or heated as much but shouldn’t be dirtier
  4. Apr 11, 2023 at 10:17 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    My 09 looked awful the first time i changed it @ 15K..after that it looked ok ...
    eltacosancho[OP] and Junkhead like this.
  5. Apr 11, 2023 at 10:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's normal. Due to the much lower quantity and that it is always spinning, it should be changed with the rear diff.
  6. Apr 11, 2023 at 10:25 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I changed all my fluids at 5k and was surprised to find more sludge in my front then the rear.
  7. Apr 11, 2023 at 10:39 AM
    eltacosancho
    Pat
    North Dakota
    Yea the front was worse than the rear. After I flushed it I filled it with Redline 85W for both rear and front. I’ll re-do the front again in about another 10k to see the condition I’ll post that update as well.
  8. Apr 11, 2023 at 10:48 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    The internals are always spun by the front drivers wheel due to the CV and the way the drivetrain is setup in these trucks.
    I noticed some very fine sludge in my front diff when I did my 60k service. Unknown history before that. Roughly the same at 90k so I am not worried about it.
  9. Apr 11, 2023 at 10:51 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It doesn't take a lot, but you can just pull the filler and judge what comes out from there. If you do it with a warm engine, there will be overflow. Or, you could dip in a white strip to get a visual.
    For reference, see the pics here:
    https://www.tacomaworld.com/threads...-manual-transmission-6mt-fluid-change.481719/
  10. Apr 11, 2023 at 10:54 AM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Did all my gearbox oils recently the front diff was definitely the worst. My guess is that the smaller volume means anything in the oil is less diluted than in the other cases.
    Correct me if I'm wrong but my understanding is that the front left axle isn't disconnected so even when not four-wheel drive the front diff is still getting turned.
  11. Apr 11, 2023 at 11:06 AM
    SR-71A
    Zack
    Southern Maine
    Exactly
  12. Apr 11, 2023 at 11:10 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There was a theory that the factory fill contains some additives for break-in that darkens it?
    I'm at 90k and am about ready to do the second swap. Did the first at 7k and checked them at 60k.
  13. Apr 11, 2023 at 11:11 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I can tell you my gen1 tundras front differential gear oil was dirty looking at that mileage, but the rear was still pretty clean. My tacoma should be coming up for a gear oil change next year....we'll see how it goes.
  14. Apr 11, 2023 at 11:11 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    :worthless:
  15. Apr 11, 2023 at 11:13 AM
    SR-71A
    Zack
    Southern Maine
    Hadnt heard that one myself. As I said above, I recall some sludge at both 60k and 90k. Even sent a sample to Blackstone at 90k. No issues according to them, other than water intrusion. Which I knew about.
  16. Apr 11, 2023 at 11:17 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's what theories are all about. Hahaha!
    Overall, it's a diff with no filter. Seeing things in the used fluid shouldn't be a surprise, although seeing it come out more like virgin fluid is always welcome.
  17. Apr 11, 2023 at 11:18 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yes, my front diff was black and sludgy compared to almost brand new looking fluid in the rear. Changed mine at 18k miles.
  18. Apr 11, 2023 at 11:20 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I would go longer than 10k on redline fluid…
  19. Apr 11, 2023 at 12:38 PM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    Agree
    :worthless:
  20. Apr 11, 2023 at 12:49 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Pretty sure Toyota recommends 30k between service
    SR-71A likes this.
