Oil drain crush washers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 147 mulie, Jul 29, 2017.
  1. Jul 29, 2017 at 2:19 PM
    #41
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    But why would you bring your truck to have the oil changed somewhere if you have a fumoto valve?
    Bagman, Blockhead and Bebop[QUOTED] like this.
  2. Jul 29, 2017 at 2:30 PM
    #42
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Why would anybody pay for something they are capable of doing themselves. 1 word- LAZY. I don't care. I make money off people that are lazy or don't know a single thing about the 30k+ piece of machinery they are driving.
  3. Jul 29, 2017 at 2:55 PM
    #43
    TexasWhiteIce
    Texas
    But then why buy the fumoto valve
    Bebop[QUOTED] likes this.
  4. Jul 29, 2017 at 3:01 PM
    #44
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I still get metal.
    Is this becasue they are not avaliable where you are?
  5. Jul 29, 2017 at 3:08 PM
    #45
    Bebop
    Nick
    No idea. But I've seen them before and I've turned them away. Company policy.
  6. Jul 29, 2017 at 4:29 PM
    #46
    TexasWhiteIce
    Texas
    Man, people are weird
    Chuy likes this.
  7. Jul 29, 2017 at 4:42 PM
    #47
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Just what I've read here but if somehow the fumoto gets smashed by a rock or branch generally the pan deforms. I have not read of any instances in which oil is lost however I'm sure there is an outlier case. Hearing about the pan denting actually makes me confident in the valve as it would seem the weak point is the flexible sheet metal which bend/dents not the brass valve or the pan drain weld-in nut. I suppose a branch that somehow gets up in that area would also be likely to grab the stock oil drain bolt, though perhaps not as much as the lower hanging fumoto.
    EatSleepTacos likes this.
  8. Jul 29, 2017 at 5:04 PM
    #48
    TexasWhiteIce
    Texas
    There's always a chance..... there's also a chance a meteor will strike the Earth making this moot
  9. Jul 29, 2017 at 5:07 PM
    #49
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Avsfreak18, 03f5sp and IronPeak like this.
  10. Jul 29, 2017 at 7:01 PM
    #50
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Another shout out for the Fumoto valve...143,000 miles and counting.
    DrFunker and IronPeak like this.
  11. Jul 29, 2017 at 8:01 PM
    #51
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I just wrap my drain plug with Teflon tape every time. It also makes it a little 'snug' when re-installing.
    I use the Fram Extra Guard 3600 so it doesn't come with a new crush washer.
    I know, my engine will probably start spinning bearings next week.....
  12. Jul 29, 2017 at 8:20 PM
    #52
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Go to napa and get a nylon washer that is tight on the drain plug threads so when you screw it down on the plug it stays, then you never have to worry about leaks and it last's forever.
  13. Jul 29, 2017 at 8:43 PM
    #53
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Nylon not last forever; it will eventually crack from the heat. Change every 3-4 oil changes; no reason to wait till it leaks - bad for the environment and the engine if you don't catch the leak.
    TRDSport10 likes this.
  14. Jul 29, 2017 at 8:56 PM
    #54
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    In the last 30 years and 10 plus vehicles, I have never had a nylon washer become brittle or crack from heat and leak, some of these have had over 200k on them with no problems.
  15. Jul 29, 2017 at 9:04 PM
    #55
    Justinlhc
    Justinlhc Not looking for a relationship
    I'm paranoid about my Fumoto valve and planned on taking it off, but I haven't had an issue with it besides the self inflicted mental :crazy:
    I do enjoy the simple oil changes...
  16. Jul 30, 2017 at 11:35 AM
    #56
    Chuy
    Lakeside, CA
    Silver Taco
    I've had them crack and become brittle; hence, my suggestion ... never had one leak, but it would have if I hadn't changed it. I, too, have been using them a long time, since early 1980's when pops started showing me to work on my own cars.
  17. Jul 30, 2017 at 12:02 PM
    #57
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Too many failures with the Fumoto valve, to have me rely on it:
    Fumoto Valve horror stories
    Fumoto Drain Valve FAIL
    Fumoto Valve warning
    Fumoto drain valve failure
    Fumoto Disaster Averted Barely
    Just a small sample of numerous threads on the internet.
    Even a warning on the Fumoto website:
    "For extreme use, while Fumoto oil drain valves are manufactured to last for the life of your vehicle and to withstand normal wear and tear when used as designed, they are a mechanical device and caution must be used if they are subject to being struck by heavy objects, the ground or at a high speed. Total failure of the valve and loss of engine oil could occur if the valve is struck with sufficient force. "
    God help you if you hit a road hazard!
  18. Jul 30, 2017 at 12:28 PM
    #58
    Chuy
    Lakeside, CA
    Silver Taco
    Failure on a Tacoma will be rare; a crossmember protects the valve from debris. If you look under the car from the front, you will not see the valve as it doesn't hang below the crossmember line.
    And those are not too many failures. Many are preventable; you should always look under your car any time hit something and check for damage and leaks.
    TexasWhiteIce likes this.
  19. Jul 30, 2017 at 2:02 PM
    #59
    IronPeak
    AuggieX
    Back to Back
    I'm going to use a suggestion found in one of those links. A sacrificial ziptie to secure the lever, nipped off with a dyke when oil x time.
  20. Jul 30, 2017 at 2:22 PM
    #60
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Which one mentioned that? That's a fantastic idea.
