Oil Drain Plug Leaking??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blm, May 20, 2025.
  1. May 21, 2025 at 12:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Holy shit!
    Once again I'll thank the good lord I don't live a the rust belt.
  2. May 21, 2025 at 12:04 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Oil pan is two pieces.
    Upper pan is aluminum, Lower pan is steel.
  3. May 23, 2025 at 8:30 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Unfortunately the 4-cyl pan drapes over the front diff, not like the small V6 lower pan.
  4. May 23, 2025 at 8:46 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    Good luck on your repair. You may fall into a pattern that adds things to your project though since you will be creating access to other issues.
    I'm late to this thread but as I read the discussion of plug threads, I kept thinking that the threads do not accomplish the seal, it's the interface between plug flange and pan nipple. With a good gasket and ability to torque the plug to spec you should not leak.
    Jimmyh likes this.
  5. May 23, 2025 at 12:37 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    on my Gen1 taco 4 cyl the oil pan rotted out and we used JBWeld and some metal and JBWeld on after that to patch it up
    my dad tractor oil pan is still holding after 10 year with same JBWeld fix
  6. May 23, 2025 at 12:42 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Not sure there's many shops that would be willing to take over halfway thru a job like that but who knows..
  7. May 23, 2025 at 1:56 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    One important thing about torque specs is that they are usually given assuming the mating faces of the threads are dry and clean (sometimes called a "dry" torque spec). As soon as there is some other medium between the threads (e.g., oil, debris, Loctite) the coefficient of friction between the mating faces of the threads changes. As a result, the same torque applied to the fastener (drain plug in this case) will generate significantly different amounts of clamping force (and shear stress in the threads).
    The numbers given here are rough, but enough to demonstrate the point: A 30 ft-lb torque applied to dry threads at a steel-steel interface for threads this size might develop a ~3600 lb axial load. Whereas 30 ft-lb applied to lubricated threads may exceed a 5000 lb axial load. Even then, I believe the actual spec for the 2.7 is 28 ft-lb, which I might adjust to ~20 ft-lb due to the inevitability of getting oil in the threads.
    For an M12 x 1.25 fastener (which IIRC is the thread size of both V6 and I4 engines in our trucks), a 20 ft-lb torque would likely generate, as just a back of the envelope calculation, a ~3400 lb axial load (whereas a clean/dry interface would produce a ~2500 lb axial load), which very likely represents a huge margin over what is actually needed to keep the plug retained and prevent leaks.
    Jimmyh likes this.
  8. May 23, 2025 at 3:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    There's an upper pan which is more like a block girdle to provide strength, and a steel lower pan. At least @blm won't have to dick around with the timing chain cover or transmission bellhousing bolts like he otherwise would with a one-piece pan...
  9. May 23, 2025 at 4:14 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    See @ClassyTacos' video. Front diff removal is the same between 2nd & 3rd gen, 4-cyl & V6. Only exception is you probably won't have the front diff temp sensor, so one fewer plug to disconnect:
    https://youtu.be/TnRm7S-ha1k?t=152
    I've attached the FSM section for removing and installing the oil pan. Consumables you'll probably need:
    Oil pan sealant: Toyota 08826-00080 or Permatex The Right Stuff 90-minute sealant
    Axle nut cotter pin: 95381-04050 x2
    Front diff seals for CV axle: National P/N 710596 (LH), National P/N 710595 (RH)
    ClassyTacos likes this.
  10. May 23, 2025 at 6:54 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Looks like those instructions are general teardown of the engine....
    Not showing what it entails to perform the repairs in-frame, if possible...
  11. May 23, 2025 at 7:44 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^You remove the diff, then you have wide open access to the lower pan.
  12. May 23, 2025 at 7:58 PM
    slater
    San Diego
    never seen one or looked under one, can you just lower the diff & snake the pan out, or does it truly need to be removed completely?
    Doing it for a living for fords, ALWAYS trying to make life easier & find short cuts when appropriate,
    Alot of times on fords we just lower the diff, leave the cv shafts attached,
    Giving us just enough room to cheat it out.
    Sometimes workshop manual states to remove subframe on certain shops, we unbolt from the body but stays in the car still attached to either sway bar links or tie rods, but hanging down low enough to do what needs to be done....
  13. May 23, 2025 at 8:08 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^This FSM figure shows the shape of the pan more accurately than the parts catalog:
    Because of the oil pickup tube, you have to drop the pan a fair bit before you can move it sideways. The front diff housing's pinion portion sits to the left of the pan, *on top* of the rear crossmember, so you can't lower that by much either.
    I included the FSM section basically to show page EM-186, which gives the tightening sequence of the pan bolts, as well as the working time of Toyota FIPG sealer.
  14. May 24, 2025 at 1:30 PM
    blm
    blm [OP] Well-Known Member
    Well I'm no expert on the subject but i have been looking up threads and watching videos for pulling CV axles, dropping diff,etc.
    I read where one claimed to just lower the diff a little but not pulling the axles. Claimed it was possible to remove the pan with the axles still connected by unbolting the pickup tube.
    To be honest my 2013 has 98K miles on it. I am considering replacing the CV axles and the hub/bearing assemblies at this time. Also new rotors and front brake pads.
  15. May 24, 2025 at 2:23 PM
    #35
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Keep in mind the pan has to be installed with a bead of FIPG sealant. If you use the Toyota sealant specified in the manual, you'll have only 3 minutes to install the pan and tighten the 20+ fasteners. You need open access to do this. Otherwise you'd most likely smear the sealant and have to re-do.
  16. May 24, 2025 at 3:33 PM
    #36
    blm
  17. May 24, 2025 at 4:20 PM
    #37
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  18. May 24, 2025 at 5:26 PM
    #38
    Waasheem
    Waasheem
    2007 xrunner
    I’m sure the above will work.
    If by chance it doesn’t, you could use permatex “the right stuff”. The one thing I don’t like about it is the claimed cure time is much more than it says.
  19. May 24, 2025 at 8:59 PM
    #39
    blm
    On second thought maybe the Felpro gasket isn't the best solution. Think I'll go the sealer route.
