Oil drain plug pitch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TseGeeLa, Feb 14, 2019.
  1. Feb 14, 2019 at 2:08 PM
    TseGeeLa
    TseGeeLa [OP] Member
    Chad
    Yoakum, TX
    ‘19 Tundra TRD Pro Black
    I’m looking for the thread pitch of the oil pan drain plug for a ‘17 3.5L. I was going to use a Fumoto valve but then found the Stahlbus version. Since they sell based on thread...
  2. Feb 14, 2019 at 2:40 PM
    TseGeeLa
    Chad
    Yoakum, TX
    The Stahlbus has a cap and no exposed lever. It uses a tool to open a ball valve and allow the oil to flow. Seems like a safer option.
    1bad2k and Vbpiper like this.
  3. Feb 22, 2019 at 8:50 AM
    freighter72
    freighter72 Member
    George
    Southern California
    2016 Tacoma TRD OFF-ROAD Extended Cab
    Husky floor mats, Toyota bed mat, Bed Header rail,
    Installed a Stahlbus valve about 4 months ago. Just did my first oil change with it. Very easy and clean way to drain engine oil. It is a little slower than pulling a drain plug but that just gives you enough time for another sip of coffee and to discover that your factory battery is leaking around the posts. DAMN IT! Off to the search bar to see what you guys recommend for a replacement battery.
    Vbpiper likes this.
  4. Feb 22, 2019 at 8:56 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There is usually a Group Buy going on for Northstar Batteries
  5. Feb 22, 2019 at 9:07 AM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
  6. Feb 22, 2019 at 9:56 AM
    freighter72
    freighter72 Member
    George
    Southern California
    Thanks for the info. Just saved a few bucks on new battery.
