Oil Durability Test
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billybob50, Oct 25, 2015.
  1. Nov 4, 2015 at 3:09 AM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    All I can say is that my '08 Mustang GT's engine was noticeably louder using RP than M1, especially at idle. I switched back and quiet again. Not sure if that's indicative of anything but I've stuck with M1 for all my vehicles since.
  2. Nov 4, 2015 at 4:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Base stocks, anti-wear packages, detergents.
  3. Nov 4, 2015 at 6:33 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    Mobil 1 is Mobile 1 and has been forever and is always going to be group IV synthetic
    and if you do this
    Mobile 1
    and new filter and oil change every 10,000 miles
    absolute guarantee your engine bits that touch that oil and need it to lubricate
    will outlive you and you family,
    barring any other non-oil related defects
  4. Nov 4, 2015 at 6:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pff...
    DoorDing likes this.
  5. Nov 4, 2015 at 1:26 PM
    B Wess08
    B Wess08 Well-Known Member
    Brad
    Redondo Beach
    06 DCLB Duaramax
    Flash Tune, Transgo Shift Kit, EGR Delete, Rear Locker
    90K the first day i got it
  6. Nov 4, 2015 at 1:57 PM
    billybob50
    billybob50 [OP] Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    Then why do they call them all synthetics and why didn't M1 came up on top?
  7. Nov 4, 2015 at 3:37 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
  8. Nov 4, 2015 at 3:40 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Pennzoil is now 100% synthetic. It's derived from natural gas.
  9. Nov 4, 2015 at 3:43 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Technically anything created from base oil through cracking, esterfication, or other chemical processes can be called synthetic. That's what the court case was about. Mobile wanted only oils created from lighter products, and not cracking, to be able to carry the synthetic label because they cost more and M1 wanted to be able to charge more. They lost to Castrols control of the market and now everything but Pennzoil is not what you would think it is. BTW cracked base oil is just fine as a synthetic, but under stress it's not as good at retaining it's chemical properties. @chris4x4 did some testing and so have several others on bobistheoilguy.
  10. Nov 4, 2015 at 3:46 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Oh, and OP your article looks like it was written in the 80's. Everyone has changed their formula for synthetic a few times since then.
  11. Nov 4, 2015 at 3:51 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
  12. Nov 4, 2015 at 5:27 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Taste test is reserved for gear oil only, that's why gear oil bottles come with a sharp nozzle tip. :devil:
  13. Nov 4, 2015 at 5:36 PM
    billybob50
    Bob
    Just surfing the web and found this. I understand it's 9 years old, would be nice to find a newer article. Maybe you can take some time, and find an independent non biased oil test to post!
  14. Nov 4, 2015 at 5:40 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Changing the filter is actually more important than the oil.
  15. Nov 4, 2015 at 6:06 PM
    #35
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    "The 4-ball test (ASTM D4172) is often used as a screening test for many different lubricant types that contain antiwear additives or similar base oil properties. Other tribo-mechanical bench tests are often used as well, including the Timken Test (ASTM D2782) and the Pin and V-Block (ASTM D2670). Because engines have different contact geometry, loads, metallurgy and speeds, numerous bench tests and test protocols are needed. It is not uncommon for several oils to be tested using two such methods and to find that the performance rankings between the oils to reverse (no correlation). This is why, among other reasons, Passenger Car Motor Oils and Heavy Duty Oils (diesel crankcase) are tested in actual engines using controlled methods such as ASTM D5533 Sequence IIIE and D5302 Sequence VE.
    Jim Fitch, Noria Corporation"
    In other words, this test is meaningless. Also pay attention to the oil weights. A 0w20 oil and a 20w50 from the same manufacturer are going to have different additive packages and base stock properties.
  16. Nov 4, 2015 at 7:25 PM
    #36
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    :rofl:
    Thanks Ding, I needed a laugh tonight.
  17. Nov 4, 2015 at 7:34 PM
    #37
    tb3625
    tb3625 Well-Known Member
    Tyler
    Ohio
    2013 Tacoma access sport
    Autozone price matches it if you show them the walmart ad online. Just did it two weeks ago as I'm not a fan of walmart myself. I purchased the mobil 1 full synthetic EP and I even saved money on my mobil 1 filter because autozone gives a discount when you buy the oil and filter together.
    billybob50[OP] likes this.
  18. Nov 5, 2015 at 4:17 AM
    #38
    billybob50
    Bob
    You know looking on the back of these pretty color oil bottles! You see all the specifications it meets, with numbers and letters. They all seem to be the same, with the exception of price! Wonder what's the next level of requirements the Automotive Industry is Demanding and how do they test he oil?
  19. Nov 5, 2015 at 11:07 AM
    #39
    Sep1911
    2016 Taco
    Well the better oils will exceed the requirements significantly, thats the important thing. ul
  20. Nov 5, 2015 at 11:14 AM
    #40
    billybob50
    Bob
    On the back of all those different pretty color bottles. They all meet or exceed current manufacturer's requirements! So which one exceeds the requirements significantly?
