oil filter 90915-20004
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yv1650c, Jun 5, 2010.
  1. Jun 5, 2010 at 4:10 PM
    yv1650c
    yv1650c [OP] Active Member
    Carlos
    Venezuela
    Hello, my new truck has installed from plant the oil filter 90915-20004. I've been searching on ebay to make a lot buy of oil filters, but i cannot find this exact model.
    Whats the difference beetwen -20004 and YZZ## filters offered on ebay? is the same filter?
    What's the part number of the TRD one? is the TRD good? or by going with the Toyota OEM installed on plant filter is ok ?
    thank you.
  2. Jun 5, 2010 at 4:45 PM
    JKD
    JKD Well-Known Member
    Not the same. Google the two part numbers (90915 -YZZD3 and -20004) and you'll find a lot of discussion on it.
    I like the -20004, but I'm not going to go to any great lengths to get it. I am happy with a NAPA Gold filter.
    Black Taco likes this.
  3. Jun 5, 2010 at 5:48 PM
    yv1650c
    Carlos
    Venezuela
    mmm, but it would be bad for my truck installing the -20004? or can i go with the yyzd3?
  4. Jun 5, 2010 at 6:13 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    You will have no issue going with the YYZD3 filter as a replacement. Most car makers have a different spec filter installed on the motor from the factory because it is usually installed with mechanical means (I.E. Robot or computer controlled install tool) and need a more robust constructed filter.
  5. Jun 5, 2010 at 6:22 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I think they used The Terminator to install mine. It was a PITA to get off the first time I changed the oil.
    YotaDriver631 likes this.
  6. Jun 5, 2010 at 7:08 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    Not uncommon regardless of make for the initial install filter. I use to work as an equipment maintenance contractor in the SATURN motor plant back in the day and seen where they installed the filter dry on the gasket and used a computer controlled install tool that counted both turns and torque. A thinner walled filter that is sold for home or mechanic install would have never held up to this process.
  7. Jun 5, 2010 at 7:45 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I say as long as it's a Toyota filter and it fits properly than you should be good to go. I only use Toyota filters on my trucks. I say if it came with it from the factory than that's what it should have on it all the time. Just my .02
  8. Sep 18, 2015 at 7:53 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Have you ever located a source for the 20004s?
  9. Sep 18, 2015 at 8:29 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I would be very careful getting any filters online unless they are from a reputable source to avoid getting fakes.
  10. Sep 21, 2015 at 7:30 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I looked into sourcing the 90915-20004 - original factory filter. Local dealer said that when he keyed in 90915-20004, the 90915-YZZD3 filter popped up as the replacement and it is.
    Searched some more and found a dealer in SoCal who said he "had a few" - he wanted $18 a piece for them. I passed on that.
    The 20004 seems to be more widely available in Europe(or it was a yr. or so ago), but the shipping would no doubt kill the deal.
    I quit worrying about it and use the dealer-provided 90915-YZZD3. Others use Wix or Napa Gold(Wix) - also good filters.
