Oil filter adapter Pro-Sport Guage
Discussion in 'Performance and Tuning' started by Valsmere, Aug 5, 2013.
  1. Aug 5, 2013 at 5:36 PM
    Valsmere
    Valsmere [OP] Well-Known Member
    Brian
    New Jersey
    EXPENSIVE
    tail gate lock, rear view mirror bracket, hood hinge brackets, and the list grows.
    If this is in the wrong section please forgive me. I got a question for the 2nd generation guys. I have a 2013 dlbc sport wih the v6 and I am looking to add oil pressure and temp guages to my truck. I plan on using a craven speed mount kit. My question is the following: Has anyone used the Prosportguage oil filter adapter plate? Is it good/no good, known issues, anything better I should look at? Thanks in advance. :D
  2. Aug 6, 2013 at 2:06 PM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    I use it. I know there are a lot of option out there but it seems to do the job just like all of the others.The four ports are nice because you can mount the sensors how you want them. I'm running oil pressure and oil temp on mine.
    Instructions are simple, screw plate on, and tighten center bolt once you have the plate oriented the way you want it. My only complaint is that you really have to crank the oil filter down on the plate or it will seep a small amount of oil.
  3. Aug 6, 2013 at 3:43 PM
    Valsmere
    Brian
    New Jersey
    EXPENSIVE
    Cool thanks for the reply. Looks like I got another project in the works. Yeah same two guages for me oil pressure and temp.
  4. Aug 7, 2013 at 4:19 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I think that Lucario Runner has that specific plate. That one or another brand, but not the Greddy one.
    If that is the same one as his, he had continual small leaking problems. Hopefully he will chime in soon enough and add the correct info. Might have been glow shift. Damn I cannot remember.
    Greddy also has one, regardless. 3/4x16UNF is what you need for the oil fitting.
  5. Aug 7, 2013 at 6:18 PM
    Valsmere
    Brian
    New Jersey
    EXPENSIVE
    Cool thanks for the heads up. I thought that was the size I needed. Thankyou for the information I wasn't 100% sure about it.
  6. Aug 7, 2013 at 7:51 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I have the glowshift one. I went and got a better o ring to stop the leaks. Ill get rid of mine when i get a air cooled oil cooler.
  7. Aug 7, 2013 at 8:24 PM
    Valsmere
    Brian
    New Jersey
    EXPENSIVE
    Thanks Lucario, I was checking out your build, gotta say Awesome 4Runner! Great way to go in a completely different direction than everyone else. Hats off to you!
  8. Aug 8, 2013 at 6:00 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Thanks for the kind words. :D
