Oil filter application question
Discussion in 'Technical Chat' started by Dudley, Jul 1, 2010.
  1. Jul 1, 2010 at 6:22 PM
    Dudley
    Dudley [OP] Cranky Old Bastard
    David
    Texas
    10 Access Cab
    Just came back from the dealer with two fresh genuine Toyota oil filters. The filters are marked 90915-YZZD3. My handy chart from a Toyota genuine parts web site lists this filter for the V6 engine. My truck has the 2.7 L 4cyl. and that is what I told the parts guy. Same chart lists the oil filter as 90915-YZZG1 for the 4 cyl. Did this guy give me the wrong filter? Can this filter be used for this application anyway?:frusty:
  2. Jul 1, 2010 at 7:58 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    You can use it.
  3. Jul 1, 2010 at 7:59 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    All the current Toyotas have the same gasket size and threading. When I upgraded from the 4cyl to the v6, the dealership told me I could just use the remaining 4cyl filters I had on the V6. If you look up a filter on Wix or Purolator's website, they only list one filter for both engines.
    It will work fine, as long as it clears the shroud deal, it will just be a bit longer.
  4. Jul 2, 2010 at 5:46 AM
    Dudley
    David
    Texas
    10 Access Cab
    Thanks. I suspect inventory reduction and corporate standardization will eventually drive Toyota to offer 1 or 2 filters for everything they make. Seems the way of most industries now. $$$
