Oil Filter Cap Stuck! I'm about to Cut IT!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VBYotaTaco, Sep 23, 2022.
  1. Sep 25, 2022 at 5:28 PM
    #41
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    I'm still amazed that Toyota decided to go with a 1950's canister oil filter technology. Really Toyota.... You can do better than THAT!...
    Makes me very happy I bought the 2.7 with a spin-on oil filter.
    davidstacoma likes this.
  2. Sep 25, 2022 at 5:55 PM
    #42
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    There’s nothing wrong with it, it works. There are torque specs for a reason, as long as they are adhered to, it’s a simple process.
    I have 2 vehicles with the 2GR and I have had none, zero problems with getting the canister off with anything more than a standard size 3/8. No cheater pipe, no impact, no breaker bar. Why? Because they go back on with a MotiveX on the end of a 3” extension being turned by….tada, a Torque Wrench…set to the spec that’s written right there on the canister. Things work when they are used as designed.
    Now I question the transition to using plastic canisters because they simply want to be cheap but the aluminum one is a cheap upgrade for peace of mind. My Lexus already had the aluminum one stock.
    Big tall dave, fmb and zoo truck like this.
  3. Sep 25, 2022 at 6:09 PM
    #43
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Just my opinion...
    the 3/8inch adapter on the filter wrench did not extend to grip strength needed to turn the housing unit...puts too much stress at that point to turn an entire filter wrench.
    An over-sized socket, which can be used on the filter wrench I have allows for a firmer grip, thus allowing a better grip on the filter wrench.
    You can use a standard ratchet on the filter wrench but leverage works better.
    I have one more ToyotaCare Oil Change which I am happy to let the dealership I'm currently visiting do--that visit is later this year in December.
    The 5th and final ToyotaCare visit (does not include oil change) will be in May 2023 which will mark the 2-year point of my ownership.
    After that, I will be doing my own oil changes which means I'll know how much torque was used on the oil pan bolt and the filter housing.
  4. Sep 25, 2022 at 6:15 PM
    #44
    BMH
    Bruce
    Yeeeeeah....
    I see multiple threads here about troubles with 'canister' filters. I see nothing about spin-on filters. Imagine that.
    And I'll still say that canister filters are 1950's technology. There's absolutely NO reason for it.
    What's Toyota gonna do next? Bring back oil-bath air filters? (If you're under 60, Google it..)
    DES2009 likes this.
  5. Sep 26, 2022 at 4:57 AM
    #45
    VBYotaTaco
    VBYotaTaco [OP] Member
    Ron
    2017 Black Tacoma TRD Off-Road
    Update, I had to cut it off. Beat, Battered, Bloody but got it off. I used a rotary cutting tool to remove most of it and then a hot screw driver to melt away the rest to not damage the treads. Replaced the old plastic cap with a metal one. No leaks, all good to go!
    The tears of relief when that thing popped off. It was definitely stuck up in there. Never again.
  6. Sep 26, 2022 at 5:28 AM
    #46
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    The Toyota care trips without an oil change, what exactly are they doing besides rotating tires?
  7. Sep 26, 2022 at 5:39 AM
    #47
    avi8or_co
    Putting the lug nuts back on as tightly as possible with the biggest impact they have….
    Or forget to tighten them at all….ask how I know about that one.
  8. Sep 26, 2022 at 5:49 AM
    #48
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    @TexasWhiteIce
    Lots of inspecting/visual inspections, fill fluid levels, brakes, lubricate/torque propeller shaft.
    It's in the ToyotaCare brochure.
  9. Sep 26, 2022 at 6:06 AM
    #49
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Wow!
    You were MORE frustrated than I was for sure! (You're actually making me feel better) lol
    If it wasn't for the second option on the filter wrench that allows a oversized socket for better grip, I would have broken off the 3/8 square wrench.
  10. Sep 26, 2022 at 8:59 AM
    #50
    TexasWhiteIce
    Texas
    So a whole lot of nothing…..
  11. Sep 26, 2022 at 11:21 AM
    #51
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The only 'trouble' would be a technician installing the housing too tight like in this post. That is not a fault of the filter, that is a fault of the greasemonkey. They still overtighten spin-on filters just the same, but it's a different process to troubleshoot and solve. Great reason to do your own oil changes either way which I do whether I have a spin on or a cartridge filter.
    BTW, they are called cartridge filters, not canister filters. Technically the only filter that has a canister would be the spin-on type that you like. I don't have a preference either way, but I certainly wouldn't choose an engine based off of that.
    Also, based on the fact that you can drain the cartridge filter housing before you remove it, technically you can save yourself from making MUCH LESS mess if you use a tool like the Motiv-X drain hose valve kit to let all the oil out first. Works great and I'm happy with the setup - I don't at all wish I had a spin-on at all, though if I did, I wouldn't be bummed about it either.
  12. Sep 26, 2022 at 11:34 AM
    #52
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Just thinking out loud: I wonder if Toyota went to the cartridge style on the modern Camry / Tacoma engines to help reduce landfill waste associated with oil changes?
    Think about it, bazillions of oil changes every year across just these two models that do not have the extra waste of the metal can associated with it. With the cartridge style, it's just a paper filter and two rubber o-rings
    That would go a long way to get them on the EPA's Christmas card list. :confused:
    fmb and tonered like this.
  13. Sep 26, 2022 at 11:49 AM
    #53
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :cheers:
    BLtheP[QUOTED] likes this.
  14. Sep 26, 2022 at 11:50 AM
    #54
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    One o ring. They don’t bother with the small one unless it has visible damage.
  15. Sep 26, 2022 at 11:51 AM
    #55
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    Congrats.
    Can relate. First oil change on my own after Toyota Care was pure hell. Been doing oil changes for over forty years. That one made me cry. Never taking it to a dealer again.
    nglescobar1992 and tonered like this.
  16. Sep 26, 2022 at 11:51 AM
    #56
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Waste was the reason noted when other automakers changed to cartridges. There is a lot of energy required to process steel, or even recycle it. Just tossing in an element makes a lot of sense to me.
    The defeatist attitude surrounding a simple cartridge makes me laugh.
    OZ TRD, fmb and Big tall dave like this.
  17. Sep 26, 2022 at 11:57 AM
    #57
    nglescobar1992
    nglescobar1992 Well-Known Member
    boogers
    2019 tacoma
    oem
    At least i was not the only one who struggle to remove the oil canister, i was able to remove a steering wheel but a oil filter took 2 days plus 1 shop did not want to do since they did not had the proper tool to remove it
  18. Sep 26, 2022 at 12:08 PM
    #58
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    Maybe it's just me, but I much prefer changing the oil on my 2020 6-cylinder with the cartridge filter than changing the oil on my 2006 4-cylinder with the spin on filter. The location of the spin on filter on my 2006 makes it a messy oil change. I drip oil all over the place trying to keep that filter level when removing it. It's up there a ways. With the MotivX drain tool, it's pretty clean and easy on my 2020. Now, our Subaru has a spin on filter at the top of the engine. That I like.
    offthewallace likes this.
  19. Sep 26, 2022 at 1:04 PM
    #59
    Buck Henry
    So you seriously chose a 4 cylinder powered truck over a V6 just because of the oil filter design?
  20. Sep 26, 2022 at 1:49 PM
    #60
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    @TexasWhiteIce
    What would satisfy your "realistic" expectations for Preventative Maintenance? (Not being facetious)
