Oil filter cap wrench for 6 cyl
Discussion in '3rd Gen. Tacomas (2016-2023)' started by moto619, May 4, 2017.
  1. Aug 11, 2019 at 10:49 AM
    wgabrock
    wgabrock Member
    Jon
    Bremen, GA
    2107 Silver Metallic TRD Sport 4x4
    A few LEDs for now....
    I have had two. The best one i got at Oreilly’s. Was about 9 bucks and the teeth are just right and strong. Might not last forever but for the money and time looking it’s worth it. Use it for my wife’s Rav 4 too...
  2. Aug 11, 2019 at 12:18 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    I have a dozen or more oil filter tools I've accumulated over the years--here are just a few, one of them always works--if not one of them will drive a big screwdriver through the damned thing:
  3. Aug 11, 2019 at 12:32 PM
    wgabrock
    wgabrock Member
    Jon
    Bremen, GA
    Don’t stick a screwdriver threw the Taco plastic oil filter HaHa!
  4. Aug 11, 2019 at 3:38 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    That is, unless you happen to have a replacement you're just itching to use.
    Jeff
    shakerhood likes this.
  5. Aug 11, 2019 at 4:40 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    I missed that this was the 3rd Gen forum...
  6. Jan 3, 2020 at 8:03 AM
    Split|Circuit
    Split|Circuit Well-Known Member
    Valley of the Sun
    2017 TRD Off 4x4 DblCab, White, Blk/Org Int
    Bone Stock
    I'm going to ask what may be a stupid question: Do I need one of these tools to remove the oil filter cap?
    I ask because I feel that my grip strength is pretty damn good, and I never used a tool to get a regular oil filter off in the past, even if it was wanged on there pretty good. Going to change the oil myself for the first time on my Taco. Is the tool required because the cap is too narrow and/or up in the engine compartment to effectively grip and twist it properly? On subsequent oil changes, the cap shouldn't be over-tightened anyway since the o-ring does the sealing...kind of like the old 1-1/4 turn tightness on a can filter.
    If I need the tool, then I need the tool, but would like to save the green if at all possible. Thanks.
    auskip07 likes this.
  7. Jan 3, 2020 at 8:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes, you do. One like the black one in the box below that grabs the flanges on the canister is highly recommended.
    On cars with a nice area around the old spin on filters, I would do it like you said, all by hand. Just not possible with the Taco. Those used compression of the seal to keep it in place. The main sealing component on the canister is the o ring with a small amount of clamp up needed between the canister and flange.
    Also, please use a torque wrench to hit the number stamped on the canister.
    Split|Circuit[QUOTED] likes this.
  8. Jan 7, 2020 at 3:58 AM
    Split|Circuit
    Valley of the Sun
    Bone Stock
    Thanks for the confirmation. Ended up buying the Motivx wrench on Amazon. Seemed like the only one that guaranteed the best grip and fit. $25 for an oil-filter wrench is a little extreme, but that's the boutique world we live in these days...
    tonered[QUOTED] likes this.
  9. Jan 7, 2020 at 6:17 AM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    its organic
    mtworm and ryan760 like this.
  10. Jan 7, 2020 at 6:27 AM
    fenmik
    fenmik Well-Known Member
    Nova Scotia, Canada
    2019 Double Cab TRD Sport.
    I found a oil filter wrench up here in Canada for my truck 64mm at Canadian Tire. It works great and only costs 9.00.
    No issues yet with it
  11. Jan 7, 2020 at 9:27 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Eh. As long as the tool works properly, that is all that is important. From what I have seen the cartridge filters are a good bit less expensive than the spin-ons that I bought in the past, so there is eventual savings there.
    Just for info, this is the one that I bought almost 2yrs ago for $12:
    https://www.amazon.com/gp/product/B073XF45NF
    It did great on the one oil change that I used it so far. I have no expectation that it will fail me.
  12. Jan 7, 2020 at 9:33 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
  13. Jan 11, 2020 at 6:36 PM
    Split|Circuit
    Valley of the Sun
    Bone Stock
    Well, I'm reporting back to say that I received my Motivx tool from Amazon the other day, and I got around to changing the oil tonight.
    First time iteration on this style of oil change, but how in the actual f*ck is this a better design than the standard spin-on filter? Can someone please enlighten me?
    I wouldn't say the new design is more tidy, even with that extra plastic, landfill piece that sticks into the bottom of the housing. Unless you're fast AF in jamming it in there, the oil still slops out. Taking the housing off was pure evil, even with the Motivx wrench. It was on there so tight that I had to use a 27mm hex socket and a cheater pipe (to help maintain alignment of the tool itself)! And 3 out of the 4 teeth on the housing cracked off! Shoot, if I would have used any other tool other than Motivx, I would have annihilated it! And what's really the point of those teeth? The only thing I can determine is that one would hit the metal clip if the housing decided to loosen itself over time, thereby stopping it from coming off completely.
    On the return to normal, I did tighten to 18'ish ft/lbs.
    I don't get the design...at all.
    PS - I have a sneaking suspicion, that because the housing was so tight on the motor, and the skid plate and the oil-filter housing itself showed no marks of previous manipulation (e.g. oil streaks, finger-tip marks, scratches, plastic indentations, etc.), the previous oil changes at the dealerships were just that...just oil changes. I can't prove it, but after 25k miles, this has me wondering...
  14. Jan 11, 2020 at 7:10 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    This and lubricated threads on a metal housing instead of the plastic filter housing works well, and makes it smooth as silk.
  15. Jan 11, 2020 at 7:16 PM
    #35
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  16. Jan 11, 2020 at 7:31 PM
    #36
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    This is user error (albeit on a user-unfriendly design). You need to push up on the Motivx wrench continuously while turning it. The "ears" on the filter cap should see no torque at all. The flutes on the filter cap take all the loads. I've done 3 filter changes so far and the filter cap still looks new. :notsure:
    Many techs spray the drain plug and oil filter housing area with brake cleaner after the job to get rid of all the oil and grease. The resulting clean, dry surface makes checking for leaks easier. I don't bother with brake cleaner, just wiping away excess oil with a rag.
  17. Jan 11, 2020 at 10:22 PM
    #37
    Split|Circuit
    Valley of the Sun
    Bone Stock
    I'm with you on this, and I believe that I pushed up to maintain a straight-on contact as best as I could. However, despite holding the ratchet+tool up with my left hand and then pulling back on the cheater pipe, it must have still angled slightly and/or flexed just enough to put pressure on the teeth to crack them off. Oh well, the teeth are completely unnecessary, IMO. It's as if Toyota designed the filter housing tamper-proof like a public toilet stall wall.
    3JOH22A[QUOTED] likes this.
  18. Jan 15, 2020 at 2:50 PM
    #38
    ProTato
    ProTato New Member
    ProTato
    2017 Tacoma TRD PRO
    @Dishsoap - Did you ever get a reply or have any additional information on this product? I've seen the same and was curious if you had an update?
  19. Jan 15, 2020 at 2:53 PM
    #39
    ProTato
    ProTato New Member
    ProTato
    2017 Tacoma TRD PRO
  20. Jan 18, 2020 at 9:55 AM
    #40
    Dishsoap
    Dishsoap Well-Known Member
    White Mountains, NH
    2016 SR5 DCSB V6
    Worked great!
