Oil filter change mishap, what to do next?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Adot, Mar 1, 2020.
  1. Mar 1, 2020 at 9:43 AM
    Adot
    Adot [OP] Member
    2014 Tacoma v6 sr5
    Lifted, 35 inch tires
    I am currently performing my first oil change (on my new to me truck, not first oil change ever) and stupid me didn’t catch the fact that I had a faulty new oil filter. Really it was just missing the rubber seal. I have a new filter in now with seal. My problem is that I turned on the engine to cycle the new oil and it sprayed out all over inside my engine bay. Luckily I saw it immediately and turned it off within 2 seconds. Still a lot of oil. How best to clean my mess? Any things I need to worry about?
    Thanks everyone. I’m an idiot.
  2. Mar 1, 2020 at 9:52 AM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    Simple Green. Soak it good and hose it off.
  3. Mar 1, 2020 at 9:54 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    You're not an "idiot" ....bad stuff happens to good people!
    I would wipe up anything I could and then do an engine bay wash....here is one but there are lots of videos out there.
    https://www.youtube.com/watch?v=PRSoRkM8GcM
    Just make sure your electrical system(s) are protected...you might want to disconnect the negative side of the battery.
    Good Luck and keep us posted....any before and after pictures would be awesome!
    Cheers brother!
    Tacotj and Jack Kelly like this.
  4. Mar 1, 2020 at 9:54 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Brake clean
    Spoonman likes this.
  5. Mar 1, 2020 at 9:56 AM
    Hooligans
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    That might be a little harsh.
  6. Mar 1, 2020 at 9:57 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    It's not a big deal, just get yourself some engine degreaser, preferably the foaming kind(is there any other kind?) and spray generously. Let it sit for a bit and spray it down with some regular garden hose water (as in not a pressure washer). There are other precautions you should take if you use a pressure washer. I think some have used simple-green diluted to at least 50:50 maybe even less than that.
    -J
    Naveronski, SR-71A and PzTank like this.
  7. Mar 1, 2020 at 1:35 PM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    Simple Green like above said. You will NEVER do that again. Old mechanic taught me a trick a long time ago, on every filter and O-ring take your finger and put a film of the oil you are using. It helps seal, and makes it easier to remove the filter, and you see if its missing a gasket.
  8. Mar 1, 2020 at 1:38 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would get a roll of paper towels and manually wipe and soak up as much oil as you can and then use the simple green.
    Lester Lugnut likes this.
  9. Mar 1, 2020 at 2:07 PM
    Adot
    Adot [OP] Member
    2014 Tacoma v6 sr5
    Hey everyone, thanks for all the replies! I really appreciate it. That is one mistake I will certainly never make again. Haha. I’m walking distance from my house to an automotive shop, thankfully. This has saved me more than once in the past. I picked up some degreaser and hit the areas where the oil spill happened. Now that part of my engine bay looks much nicer! I think later this week I’ll pick up some simple green and polish up the rest. Once again thank you! I need to get better about the before and after photos.
  10. Mar 1, 2020 at 2:29 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Thanks for the update :thumbsup:.
    JimIowa likes this.
  11. Mar 1, 2020 at 5:39 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
    DG92071 likes this.
  12. Mar 1, 2020 at 6:31 PM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    Just don't put high pressure water near anything. Just use a garden hose!!!
    DaveInDenver and DG92071 like this.
  13. Mar 1, 2020 at 6:38 PM
    Hooligans
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    That's good advice, but I've always hit mine with the car-wash pressure wand about once a year and the only problems I've ever had were a wet distributor (older car obviously) and the occasional wet spark plug which corrects itself in a minute or so. Of course I don't blast the electrical stuff directly or anything..
  14. Mar 1, 2020 at 8:27 PM
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    I just got done doing this myself today, I just gingerly use the pressure washer. It seemed to work well but I didn't have any degreaser, it's still better than when I started.
    Hooligans likes this.
  15. Mar 3, 2020 at 12:30 PM
    CanisLupus
    Stokesdale | NC
    Lol, use it all the time. Ain't gonna hurt nothing
    gasgasman and MARSHBUSTER like this.
  16. Mar 3, 2020 at 12:56 PM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    at least it wasn't the transmission fluid accidentally drained :anonymous:
  17. Mar 3, 2020 at 1:02 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Ha, reminds me of the time I changed the oil on my old Fox Body mustang. The filters are below the engine off the side and I did it in a parking garage with little light (changed the oil hundreds of times on that car). Well this one time I did not see (since it was dark) that the old filter o-ring stuck to the engine block. I put the new filter on and started her up... all of a sudden my low oil pressure light comes on so I shut down the car... THEN I see oil oozing everywhere from out underneath the car. Lesson learned!
  18. Mar 3, 2020 at 1:06 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Yeah, no reason to judge. Like @gkomo, I once put on a new filter and didn't notice the o-ring from the old filter was still stuck to the engine block. Same thing happened with oil spraying out. If you notice quick enough you really don't lose much oil volume and won't hurt anything other than your pride. Sure does make a mess.
  19. Mar 3, 2020 at 1:10 PM
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    My first thought was obviously, "Crap I hope I didn't F up the engine"... second thought, "well sh*t, how am I gonna clean this up!?!" I had to ride my bike to a grocery store nearby and carry kitty litter back since I didn't have another vehicle. What a pain that ordeal was.
    dawgn86 likes this.
  20. Mar 3, 2020 at 3:41 PM
    Stormtrooper457
    Stormtrooper457 Well-Known Member
    Indiana
    2013 TRD Sport DCLB
    Nano Ceramic Tint Heated Clazzio Seats TRD Pro Wheels Softopper
    Make sure you dilute the simple green and don't let it sit for long before rinsing. It will stain and etch plastic.
    Clearwater Bill likes this.
