Oil filter change
Discussion in '4 Cylinder' started by slackinoff, Jul 22, 2015.
  1. Jul 22, 2015 at 2:15 PM
    slackinoff
    slackinoff [OP] New Member
    2010 Tacoma Prerunner 2.7 5spd
    Hey guys I just picked up a 2010 tacoma 2.7. The dealer had just changed the oil but the filter looks to be off brand. Can I change the filter without draining the oil?
    Thanks,
  2. Jul 22, 2015 at 2:17 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
  3. Jul 22, 2015 at 2:19 PM
    slackinoff
    Would it be less of a mess if I drained first? I was planning on getting a big ziplock around it once it starts to spin off, maybe that will help.
  4. Jul 22, 2015 at 2:21 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    How about you leave it alone till you need to change the oil?
    True not all filters are the same but they do the job just fine for a normal truck.
    DustStorm4x4 likes this.
  5. Jul 22, 2015 at 2:24 PM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    Just leave it. The "oem" toyota ones are just made in Thailand trash. I use fram, wix, bosch, anything I can get my hands on for my 94 Supra turbo. Your little 4 cyl will be fine, don't worry.
  6. Jul 22, 2015 at 2:24 PM
    slackinoff
    Ok fine then I will leave it be.
  7. Jul 22, 2015 at 2:27 PM
    slackinoff
    Thanks guys, wasn't looking forward to doing it anyhow.
  8. Jul 30, 2015 at 2:10 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Yeah I would leave that filter on unless you are planning an extended OCI, then you can replace it halfway through. You only need to top off the oil if the level gets at or below the "add" mark, which I doubt it will due to a filter change (assuming the level started well into the safe zone).
    How to avoid a mess when removing the oil filter on 2nd Gen Tacoma 2.7:
    Cut a piece of cardboard 6" x 10" (15cm x 25cm) and wedge it up behind the filter, between the filter and the engine block. I curve mine lengthwise a little so the oil is directed to the center.
    Then slowly unscrew the filter, allowing the oil to drain onto the cardboard instead of onto the engine block. Then carefully remove the filter. Once in a while I get a few drops on the engine block but for the most part it is clean, this is a quick, cheap and easy way to do it clean, much cleaner than just removing it without any preparation.
  9. Jul 30, 2015 at 2:16 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    If this was a Toyota dealer, why would they use an off-brand filter?
  10. Jul 30, 2015 at 2:22 PM
    DGXR
    Friend
    Sacramento, CA
    I don't think they would use an off-brand filter, they would use Toyota filters. Viewed from certain angles, the Toyota filters can "look to be" off-brand, which is what the OP claims. There is no proof it is an off-brand filter, just speculation, so this thread is kind of pointless.
