Oil filter change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tocoma rock, Aug 11, 2023.
  1. Aug 11, 2023 at 3:30 PM
    Tocoma rock
    Tocoma rock [OP] Member
    Mario
    When changing the oil filter is it necessary to remove the center drain plug I was told the dealership just drop the canister and leave the center drain plug
    David2431 and HondaGM like this.
  2. Aug 11, 2023 at 3:33 PM
    Tacoma Mike
    Southern Maine
    I never pulled it.
    Was easier for me to just drop the canister. More control on the rate of “leakage”
    And, one less seal to get screwed up
  3. Aug 11, 2023 at 3:34 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I would. Why not drop the plug? It takes 30 extra seconds. The filter is not at the low point of the reservoir.
    Unless you're talking about the filter drain. That's optional. I found it to be less messy to drain the filter first.
  4. Aug 11, 2023 at 3:43 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    No it is not necessary.
  5. Aug 11, 2023 at 3:48 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Nope, never pulled mine. Not that I didn't try. Someone must have installed mine into the housing with a power tool. Couldn't even get it free with it in the vice. Yes, I'm the original owner. No, no one else has ever changed my oil, it was like that from the get go.
  6. Aug 11, 2023 at 3:58 PM
    Tacospike
    Two Trucks
    This.
    I take it off and shove that little plastic drain thing up it to empty the filter and replace the rubber ring on it too. Kit comes with both rings, I’m going to use both rings.
    I do it for both trucks. Works for me.
    But as noted above. Not required.
  7. Aug 11, 2023 at 4:07 PM
    Cyberfool
    Cyberfool Well-Known Member
    Jack
    Balto MD
    I would do it.
    Tocoma rock[OP] and HondaGM like this.
  8. Aug 11, 2023 at 6:52 PM
    BillyE
    BillyE Well-Known Member
    I don’t
  9. Aug 11, 2023 at 6:57 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I generally just drop the canister but am thinking about changing the drain plug O-ring the next time I have it off.
  10. Aug 11, 2023 at 6:59 PM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    I do. A little less messy. Not a lot of time added to task.
  11. Aug 11, 2023 at 7:12 PM
    Bishop84
    Bishop84 Well-Known Member
    At home? Yes. Way less mess.
    At work on a hoist? HELLLLLLLLLLLL No. I spin the whole thing off and let it puke out. GOGOGOGOGO
  12. Aug 12, 2023 at 5:15 AM
    mdh_us
    mdh_us Well-Known Member
    I remove it and to drain the oil out. I think there is less mess doing it that way and you wouldn't get the filter socket full of oil or all over the truck.
    Tocoma rock[OP] and zoo truck like this.
  13. Aug 12, 2023 at 5:28 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Depends the size mess you wish to make. Don't drain the oil filter housing by removing this plug, you can make a bigger mess.
  14. Aug 12, 2023 at 5:37 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    get the motivX oil change kit, way less mess. comes with a screw in filter housing drain and hose, housing wrench, and funnel to fill the oil. you can do it without removing the drain but, it is MESSY for you, the truck, and your work area. the plastic thing that comes with filters is a joke. Ski
  15. Aug 12, 2023 at 5:40 AM
    gr8-wrx
    gr8-wrx Well-Known Member
    East Bay, SF Bay Area
    2022 Tacoma SR5 DCSB 2WD
    I haven't changed the Tacoma's yet, but on my wife's Highlander, I've just always just dropped the canister.
    Tocoma rock[OP] likes this.
  16. Aug 12, 2023 at 1:42 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    This ^^^^^
  17. Aug 12, 2023 at 1:49 PM
    Rusty66
    Rhode Island
    It’s not a bad idea to take it out every 5 or 6 oil changes since the pressure relief valve lives there. I pulled one on a high mileage Camry and there was a lot of “gunk” in there.
    TA2016[QUOTED] likes this.
  18. Aug 12, 2023 at 2:06 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    First time changing oil in my Tacoma a couple of nights ago. Had Motivx canister grip adapter AND the Motivx adapter tube to drain the oil first. Enough oil drained through the tube to convince me it was worth it.
    Someone apparently use the drain-plug-plate as a torque-point to tighten the entire canister because my 1/2 in 18-in long breaker bar was needed to remove that drain plate (needed JUST A LIITLE more than what the ratchet wrench provides, not too much more).
    But with respect to all of the other responses ... Your Mileage May Vary. :)
  19. Aug 12, 2023 at 2:18 PM
    TA2016
    Oregon
    That’s my thinking too. I changed my oil 3 times leaving the drain plug O-ring intact. I will change the drain plug O-ring next oil change.
  20. Aug 12, 2023 at 2:50 PM
    skidooboy
    central lower mich
    spin the filter drain loose with an impact. then the cannister housing doesnt move. if they are really stuck, using a breaker bar, may just spin the cannister housing off, without loosening the filter housing drain. Ski
