Oil Filter Drain Plug Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xmixpixx, Nov 15, 2009.
  1. Nov 15, 2009 at 3:46 PM
    xmixpixx
    xmixpixx [OP] Well-Known Member
    Lancaster, PA
    05 SR5 TRD Off Road 6 spd
    This is my first post on here, although I get a lot of help by searching through other peoples post. My question is (and I think I know the answer to it)..
    I was changing my oil and putting the little drain plug back on the spill pan for the oil filter, and I dropped it. I am assuming this is a non-factor, other than I need to remember this the next time I change my oil, or get a replacement between now and then. Basically I just want to confirm that this only aids in changing oil filters and doesn't affect the functioning of the truck. Thanks.
  2. Nov 15, 2009 at 5:39 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    what little drain plug?i have just a black plastic slip over cover on mine.and no it will not affect anything until u go to change your filter and the oil runs down the hole.
  3. Nov 15, 2009 at 6:21 PM
    xmixpixx
    Lancaster, PA
    That's what I thought, but it was dark out and I couldn't see under the hood very well. Thanks
  4. Nov 15, 2009 at 6:39 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    My rubber plug has been gone since maybe my fourth oil change (#19 coming up).
  5. Nov 15, 2009 at 6:39 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    gotcha.
  6. Jun 17, 2015 at 7:21 PM
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2015 DCSB TRD Pro
    Anyone know the part number for the little plug?
    Jon
  7. Jun 17, 2015 at 7:29 PM
    DouginNC
    DouginNC Well-Known Member
    Doug
    North Carolina
    2014 Double Cab TRD Sport
    I don't have one either. Probably disappeared at the first dealer oil change. I don't need it.
  8. Jun 17, 2015 at 7:32 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    You can probably find something that will work at auto zone or advanced. They sell little packages of different-sized small rubber caps in the "HELP" section...
  9. Jun 18, 2015 at 12:33 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    '15 Tacoma PreRunner V6 SR5 Auto
  10. Jun 18, 2015 at 6:48 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    2009 & 2013 and neither had one
  11. Jun 18, 2015 at 8:01 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Birmingham, Al
    2014 MGM TRD double cab 4x4
    Ome, dakars, arms, skids, sliders odds n ends
    My 14 has one. Looks to me nothing more than a. Vacuum cap for a manifold. Maybe 50 cents at a part store.
  12. Jun 18, 2015 at 11:37 AM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    Mine was missing after oil change at dealer, I asked them about it and they acted like they didn't know what i was referring to. Local hardware store had rubber screw protector for 41 cents, works fine. I now do my own oil changes.
  13. Jun 18, 2015 at 11:52 AM
    beertimecontinuum
    beertimecontinuum Drunken Yard Fab
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB V8
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    I just ran a 3/8"hose down from the nipple to near my pan drain plug. Now when I change my oil the filter spill drains down to my collector pan for easy clean up.
    jmaack likes this.
  14. Jun 18, 2015 at 12:15 PM
    jmaack
    Justin
    Birmingham, Al
    ^ good idea
