Oil filter help??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cleveland48, Jul 29, 2012.
  1. Aug 10, 2012 at 4:34 PM
    #61
    oldstick
    oldstick Medicare Member
    GA
    I know for a fact I DO NOT want a $40 K&N high airflow filter under those conditions....
    :D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
  2. Aug 10, 2012 at 9:57 PM
    #62
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    No, they are not made in the same factory as Frams.
    Fram makes Fram, Pennzoil, and MicroGuard... there are a couple of others but they are not widely available.
    The stock Toyota filter used to be comparable to Purolator, and 10-15 years ago was likely made on the Purolator line, but that seems to have stopped, possibly with the Purolator/Bosch merger.
  3. Aug 10, 2012 at 10:04 PM
    #63
    Rich91710
    Rich
    Los Angeles
    08 Base
    Filtration media area - Fram uses significantly less media than most other manufacturers.
    Seal quality - Fram's bypass seal has been shown to leak... this allows unfiltered oil to bypass the filter media even when the filter should not be in bypass.
    Also, the anti-drainback valve leaks, which reduces oil available during cold startup on engines such as the newer 4.0 using the inverted filter. This is a non-issue on the 2.7.
    And that's not even getting into the cheap cardboard endplates glued to the end of the media.
    But at least it's better than the Champion Labs (Supertech, AC Delco, STP) "E-Core" design, which glues fiber endplates to the media, and it's wrapped around a cheap plastic cage center core support that has been shown to collapse. At least Fram still uses a steel center core.
    Today's Fram is not the Fram that we grew up with in the 70s.
    It was a good filter before Allied Signal bought the name.
  4. Aug 10, 2012 at 10:07 PM
    #64
    Rich91710
    Rich
    Los Angeles
    08 Base
    And even if that were true, there's no reason NOT to use Toyota OEM filters when they are available at less than $4.50 a copy online with shipping (in quantity, shipping is the greater of 10% of the order about or $10).
    Read above... TWENTY OEM filters... enough for 100,000 miles. $88 shipped.
  5. Aug 10, 2012 at 10:08 PM
    #65
    Rich91710
    Rich
    Los Angeles
    08 Base
    All "0w" oils are synthetic.
  6. Aug 11, 2012 at 5:04 AM
    #66
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
  7. Aug 11, 2012 at 9:47 AM
    #67
    Rich91710
    Rich
    Los Angeles
    08 Base
