Oil filter help!?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dos ballenas, Feb 25, 2010.
  1. Feb 25, 2010 at 6:38 PM
    dos ballenas
    dos ballenas [OP] New Member
    tacoma 4x4
    Howdy,
    First time posting... long time tacoma owner. This site seems pretty good so far...
    So I just bought a 2007 tacoma regular cab 4x4 with the 2.7l 4 cyl.
    I owned a 2 wheel drive 1996 tacoma for its entire life and decided it was time to get the 4x4...
    So far I love the truck, but I recently went to change the oil and have been encountering some problems...
    So I go to NApa auto parts and they sell me the oil filter that their book says will work. Right off the bat I realize its the exact same filter for my previous tacoma... odd but its possible.
    I get home, remove the oil and filter and go to check the new filter against the old filter oring. Hmmmmn, they don't seem to be the same, the one I removed that is the toyota brand looks bigger.
    Concerned, I drive to Kragen auto and reference the fram filter.... also the same filter for both the 1996 and 2007... okay, maybe I was just trippin and the filter is the same. Guy at the store says to check it again and if its close to give it a try and it should work...
    I think he is an idiot, but decide to try it. So I get home and convince myself that the Napa filter is close enough, and hey, its the one the book says is right so I install it...
    No leaks so far but I still need to give it a test drive... Drive to work and let the truck sit all day... before leaving work I check it again , and what do you know, its leaking.... not a lot, but its leaking.
    Anyways, my QUESTION is: has anyone else had this problem? Is there an aftermarket filter even available?
    How can Napa, and Fram have the wrong part listed?
    I've been changing my oil for over ten years... so am I doing something wrong?
    You should know that when I bought the truck I had it undercoated by Rhino liners with ther spray on stuff...
    Could the rhino liner have casued any problem when installing the new filter? The original filter I removed was SUPER tight and hard to remove, but that could have been because the numnuts at the toyota dealership over tightened it... or did the rhino liner make it stick???? Or just the wrong filter???
    Where do I get the right filter?!?
    Thanks for the help, much appreciated!
  2. Feb 25, 2010 at 6:48 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    owyn. i dont use FRAM. i do not know if the negative comments flying about on the internet are true..but i wont take the chance.
    i bet the stock filter from a toyota dealership isnt much more $$ than the FRAM.
  3. Feb 25, 2010 at 6:49 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    First, I think you made the mistake of getting the part number from the guys at the desk. Second, every time I get a filter, they will have a parts book next to the filters. And I use that, instead of the high school kids at the desk. I also triple check the parts numbers just to make sure, etc, etc.
    Also, don't use Fram filters at all, they ARE the worse filters you could get. Use something else, or go to the dealership and they will get the right filter for you.
    Also, you may want to try to go somewhere else if possible, Autozone is usually a good place to go. Hope that helps.
  4. Feb 25, 2010 at 6:54 PM
    dos ballenas
    tacoma 4x4
    ya I know asking those guys was a mistake... so I looked it up myself in the book... and they were right.
    Its pretty odd that the napa brand, and the fram brand are both the wrong size... I guess Ill go get one from toyota from now on...
    thanks for the info on fram... taking it back tonight!
    any thoughts on the undercoat being a problem?
  5. Feb 25, 2010 at 7:04 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Why would it be a problem? I don't understand. Did they spray Rhino lining on the old filter? The only problem I would see in that is if the new oil filter has a bigger diameter. And the rubber seal on the filter goes against the Rhino lining, and not the flat metal surface. If this is the case, then getting the right sized diameter, like the old one, it should be fine.
  6. Feb 25, 2010 at 7:06 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Just use OEM. A good substitute that I use is Purolator PureOne.
  7. Feb 25, 2010 at 7:07 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    stick with the oem filter
  8. Feb 25, 2010 at 7:34 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    LOL what does that say about you?
  9. Feb 25, 2010 at 8:30 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
  10. Feb 25, 2010 at 8:34 PM
    dos ballenas
    tacoma 4x4
    with tools like this on this website its no wonder why the quetion I asked was never responded to. I had the book right there and was reading the same part number the clerk was. Seems unlikely that two stores and tow diff filters would both be incorrect but who am I to argue.
    thanks for the info guys thats all I needed.
    peace
  11. Feb 25, 2010 at 8:39 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
  12. Feb 25, 2010 at 8:52 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
  13. Feb 25, 2010 at 9:27 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
  14. Feb 26, 2010 at 2:34 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Was the NAPA part #1348? It may be smaller than the oem, but it doesn't matter. The gasket should be close to the original filter gasket, but as long as it seats against the housing it will be ok. The only reasons for leakage would be:1) The old gasket did not come off with the old filter and you have a double gasket. 2) You did not lubricate the seal before you installed the new filter. 3) The new gasket has a cut which sometimes happens during packaging or shipping. 4) The undercoating is on the filter housing and needs to be removed with a scuff pad.
    That's all I got for you. Good luck.
  15. Feb 26, 2010 at 2:42 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    When you look up after market filters, every Tacoma uses the same one. I happen to sell AC Delco at my Chevy dealer and every Tacoma engine uses a PF53 for example. Toyota has more than one filter and I don't know why. The difference in size is not enough to matter, but there may be a difference in the back flow valve or the internal filter media. Again, I don't know why there would be, but they must have a reason.
    Scroll down the cross reference and see how many Toyota part numbers cross over to the Wix part number 51348. Why do they have so many? I count 17 Toyota numbers.
    http://c2c.activant.com/ctoc/index.jsp?ID=ZFjtsKCM1AAAFS1ExCE5FfylCVlVyDylpGwAA
  16. Feb 26, 2010 at 2:45 PM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    You can use the Fram 3614 small
    0r
    the Fram 3600 large
    the letters in front just designate the quality
    TG = tough guard
    XG = extra guard
    NAPA should cross reference with these
    FRAM 3614 = NAPA 1269 -or-1348-or-1374
    FRAM 3600 =NAPA 1516 -or-1762-or-1764
    Nothing wrong with FRAM FILTERS
  17. Feb 26, 2010 at 2:48 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    NWtacoma, I'm not sure what you are trying to do. But implying someone is stupid is not what I think we should do with members, especially a new member. You don't even know the guy, how old are you anyways, 15?
    He is a new member that needed help, and all you're doing is driving him away from this site and not helping him. :smack:
  18. Feb 26, 2010 at 3:43 PM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    good info. i think that damned PH3614 is used on almost anything. i've seen it on Saturns and even a Briggs & Stratton 12 horse motor.
    to the OP: go to your local dealer and get the OEM filter...should be around $6. you spent the money to buy a nice truck, right? don't skimp a couple bucks on the filter.
  19. Feb 26, 2010 at 4:38 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Well said, I agree 100%.
    OP, I have the 2.7L engine and I use the OEM filter. I bought a case of ten of them online from these guys.
    http://www.trdparts4u.com/Scripts/p...ogid=1&catalogname=Accessories&idCategory=-86
    Welcome to the forum :)
