Oil Filter Housing Cap Won’t Come Off - Spins the housing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mattwhit08, Jan 1, 2022.
  1. Jan 1, 2022 at 9:06 AM
    mattwhit08
    mattwhit08 [OP] Well-Known Member
    2018 Tacoma TRD Sport Double Cab
    Howdy folks,
    Any remedy for a pesky oil filter housing cap that just spins when you put the 3/8” extension into it to spin it out?
  2. Jan 1, 2022 at 9:10 AM
    Bishop84
    Bishop84 Well-Known Member
    Small impact gun, like a dewalt 1/4 always gets them off.
    Honestly you can just leave it, crack the housing loose and let it drain, then remove.
    MeefZah and mattwhit08[OP] like this.
  3. Jan 1, 2022 at 9:13 AM
    mattwhit08
    Tried the impact with no luck. Went the route of just removing the whole housing. Made a mess, but is what it is.
    Was it just over-torqued by the guy who did the last oil change?
  4. Jan 1, 2022 at 9:15 AM
    Bishop84
    Yea, most techs are terrified of leaks so they always tighten too much.
    I never use the cap unless there's an aftermarket skid plate. It's messy but faster.
    mattwhit08[OP] likes this.
  5. Jan 1, 2022 at 9:39 AM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Probably cross threaded will it leak if started briefly. Look for a new housing. Might have to be broken up to get off . Let's hope no damage to the threads on the engine. Or cracked off leaving the housing threads on the engine. May need to get it in the air.
  6. Jan 1, 2022 at 9:40 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    my first oil change on my 2016 that happened and i did what you said and also on all oil changes after, have never used that drain gizmo would not even know how to. messy a bit, that's what old shop rags are for.
    mattwhit08[OP] and Grossomotto like this.
