Oil Filter Housing Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrMolotov, May 7, 2024.
  1. May 8, 2024 at 2:54 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    You will only lose maybe half of a quart
    MrMolotov[QUOTED][OP] likes this.
  2. May 8, 2024 at 3:06 AM
    MrMolotov
    MrMolotov [OP] Well-Known Member
    Ples
    2022 Tacoma SR5 4x4
    None
  3. May 8, 2024 at 3:07 AM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    Really? If I fill it with oil and then change the filter it wont all drain out? Nice!
  4. May 8, 2024 at 3:59 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I would NOT do that. Even a tiny hole, under pressure you could lose a good bit of oil and your engine fast...
    Call the dealer and maybe they'll have some shred of sympathy and get a less expensive tow there. I would not drive that!
    soundman98 and t0p_d0g like this.
  5. May 8, 2024 at 4:09 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Had this same problem. Get the aftermarket aluminum made by motivx as someone else mentioned, and use a heat gun on the housing first on a low setting. You don’t want to melt it, but get it warmed up. Should come right off.
    t0p_d0g likes this.
  6. May 8, 2024 at 4:11 AM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    Oh! I do have a heat gun! That would work?
  7. May 8, 2024 at 4:20 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    1) Get a 5lb tub of creatine and start hitting the gym
    2) once you get it off, do not over tighten it when you reinstall it.
    3) if you can F up a plastic oil cap, you can really F up a metal one
  8. May 8, 2024 at 4:22 AM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    I mean I don't even need the gym. I'm just shredding caps bro.
  9. May 8, 2024 at 4:27 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    :rofl: Just make sure you put some motor oil on the threads & don't gorilla it on there.
    You'll be fine :)
    t0p_d0g likes this.
  10. May 8, 2024 at 4:55 AM
    TS4x4
    2018 TRD Offroad
    It worked for me. I spent about five to ten minutes on a medium low setting gradually getting it warm. After that, no problem. Make sure to clean the threads on the housing and the cap of any debris or old oil that might be in there. Then smear some fresh oil on the threads before reinstalling. Same goes for the new O ring. I can guarantee the people at the dealership probably didn’t do that and caused it to seize up. Plus they most likely over torqued it too
  11. May 8, 2024 at 4:57 AM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    Hell ya. I'll try it in a few hours when I get off work. Thanks!
    TS4x4[QUOTED] likes this.
  12. May 8, 2024 at 6:32 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    For the record, I believe the spec is 18 ft. lb for the oil filter housing. 2 ft. lb. may not make a difference. :notsure:
  13. May 8, 2024 at 6:57 AM
    Shellshock
    Iowa
    I believe that’s correct. I’ve always done 30 drain /20 filter /10 filter drain cuz it’s easiest to remember.
  14. May 8, 2024 at 7:03 AM
    Pungo1
    Pungo1 Well-Known Member
    Mark
    Hey, a related question (maybe).....I've seen youtubes of folks spraying brake clean in the plastic housing and inside where the housing connects to the engine before putting it all back together. How do folks feel about this to get rid of debris? I think brake clean just evaporates and won't contaminate, but wanted opinions (and I know I'll get opinions from being around this place for a year or so....LOL) No, I'm not "parting it out" and no, it's not Friday funnies.
    MrMolotov[OP] likes this.
  15. May 8, 2024 at 7:15 AM
    #35
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    Someone, somewhere has to have video of the oil change technicians ( for lack of a better word) putting these things on with Herculean effort and 185+ ft lbs...
    t0p_d0g and MrMolotov[OP] like this.
  16. May 8, 2024 at 12:27 PM
    #36
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    removing the oil filter will not drain the oil that is in the engine pan.
    kahanabob likes this.
  17. May 8, 2024 at 3:08 PM
    #37
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    There is no gap to collect debris and spay the cleaner. The lip on the cap is flash with the lip on the housing when installed correctly.
    Koolbreeze7 likes this.
  18. May 9, 2024 at 2:05 AM
    #38
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I use isopropyl alcohol in a spray bottle to flush/rinse. Shop air to dry
  19. May 20, 2024 at 4:43 AM
    #39
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    Sorry for the late reply, but I bought an Impact Wrench and got it off with ease. Installed the new filter, metal housing, and one of those Quick Drain Valvo oil plugs too so next change should be easy. Thanks for the help fellas!
    skidooboy, Barsoom and faawrenchbndr like this.
  20. May 20, 2024 at 5:04 AM
    #40
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Great to hear you got it sorted out
