Oil filter housing, thread busting mistake. 2012 prerunner
Discussion in 'Texas' started by kawas3383, Feb 17, 2014.
  1. Feb 17, 2014 at 9:18 PM
    kawas3383
    kawas3383 [OP] New Member
    2012 prerunner
    I own a 2012 V6 fourdoor prerunner. I made the mistake of messing up the thread on the oil filter housing when i was installing the filter, so she leaked out most of the oil. I drove for about eight miles and then i lost all power and she stopped. My question is at what temperature does the engine shutdown and what damage comes to the engine when she is forced to shutdown? The oil used is a 5 w 30 API Service SN Pennzoil. Also when it comes to the oil filter housing, must I replace the whole unit or can I only replace the male where the filter screws in to?
  2. Feb 17, 2014 at 9:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sounds like major engine damage to me if she stopped running. The last thing I would worry about is the housing itself.
  3. Feb 17, 2014 at 9:30 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    When you say stop running, you mean like it went into fail-safe mode?
  4. Feb 17, 2014 at 9:31 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    This is twice we have seen this in the last three weeks. Something is going on here
  5. Feb 17, 2014 at 9:33 PM
    kawas3383
    2012 prerunner
    Steering when out, when I popped the hood no burning smell but definitley a lot of heat
  6. Feb 17, 2014 at 9:35 PM
    kawas3383
    2012 prerunner
    It wasn't a forceful stop, but I lost my steering.
  7. Feb 17, 2014 at 11:03 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have not had an issue with the 20 oil changes or so I have done on my 2012. I think the issue might had been underlying user error when changing out the filter. Not insulting the OP. I am just saying.
  8. Feb 17, 2014 at 11:22 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Nothing to lose at this point. Fix the housing, fill the oil and see how she runs. Unless you're still under warranty. If so go to the dealer explain what you did and they might inspect it for free.
  9. Feb 18, 2014 at 4:47 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Tow it to the dealer.... yikes
  10. Feb 18, 2014 at 5:13 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Not sure if the dealer is going to warranty your own fuck up.
  11. Feb 18, 2014 at 5:29 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    You're probably fine, truck has a sensor for low oil pressure and shuts off as soon as it senses no oil pressure. Also, the filter should be cross threaded, the housing might still be ok, I'm assuming the metal on the filter is weaker than the metal on the housing, also usually it's the female side that gets torn up, the male side can usually be repaired with a small file. Either way, repair or replace oil filter housing, refill with oil and hope for the best. Good luck!
  12. Feb 18, 2014 at 12:51 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    I agree the computer probably shut it down before any major damage was done. I've seen threads here where dealerships have forgot to put oil into a truck and when the owner started to drive off it's shut down. Dealership always just offers an extended warranty because they know the computer shut it down before any major damage was done. In your case it just took longer because there was oil that was leaking out vs being left out. Get the housing changed, fill it up and have it evaluated if you need the peace of mind.
  13. Feb 21, 2014 at 5:52 PM
    TxFireman
    San Antonio, Texas
    Yes, they do, but I guess the short trip isn't enough to trigger it. Usually, from the threads I've seen where folks here in the forums have experienced it, it's when they start up and start to leave the dealership that it shuts off. By that time it's been started twice and although each time, the drive time is not very far, I guess it's finally enough. I would suspect there is probably still oil up in the channels at the first start up, so for a moment the engine is moving oil. Probably just about long enough for someone to pull it from the bay out to the waiting area. Then the owner hops in starts it up and gets to the end of the lot and it dies.
    Over all, I wouldn't want to subject my engine to it. But those who have had it happen, say everything seems normal afterwards, and they seem to be mostly content with the dealerships free extended warranty to cover any future issues that might result. In the OP's case, he had oil in it, so as he was loosing it, up to a certain pint he still has oil pressure. I would assume that once the pressure dropped to a certain point, the computer kicked in and shut it down. In an older car this would not happen, and the shut down would likely be the result of irreversible damage.
