Oil filter housing torque specs.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jun 20, 2023.
  1. Jun 20, 2023 at 4:38 AM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    What ft.lbs are you guys tightening these oil filter housings at? I recently did my first oil change and used a torque wrench at 18ft.lbs but it surely did take much until it beeped. I checked the filter housing last night seems to have a damp appearance to it on the plastic. I’ll check again tonight and maybe torque it down more if you guys suggest a higher torque spec? Yes the o ring is deff in the correct location I triple checked that when installing it.
  2. Jun 20, 2023 at 4:43 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Cap is 18, plug is 10. I would not go more than that.
    Gfenza89[QUOTED][OP] likes this.
  3. Jun 20, 2023 at 4:48 AM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    Is it damp or isn't it ?
    It seals on the o-ring. Over tightening the housing will not help weeping. Did you lube the o-ring before installing?
  4. Jun 20, 2023 at 4:49 AM
    Gfenza89
    Yeah I wiped some clean oil around the oring. I gotta get a better look at it. It could just be from wiping oil on the oring that big of seepage down through the threads
  5. Jun 20, 2023 at 4:51 AM
    MrMustacho
    MrMustacho Well-Known Member
    This right here ^
  6. Jun 20, 2023 at 4:52 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Zero ft lbs. Tightness has nothing to do with seal of the internal oring.
  7. Jun 20, 2023 at 4:53 AM
    steel wheels
    should be no seepage past the o-ring. perhaps the "wet" is from what you put on the o-ring
    Gfenza89[OP] likes this.
  8. Jun 20, 2023 at 4:53 AM
    Gfenza89
    That’s what I’m thinking
  9. Jun 20, 2023 at 5:00 AM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    https://empyreoffroad.com/blogs/res...toyota-tacoma-diy-maintenance-reference-guide
  10. Jun 20, 2023 at 5:02 AM
    jeezumcrow
    jeezumcrow Well-Known Member
    Charlotte, NC
    If you put more torque, you're risking breaking the o-ring. If the thing continues seeping, I'd take it a part - I know, another oil change - and inspect it.
    In general, in o-ring fittings you want to maintain the integrity of the ring. It should come on not twisted and seal within the torque specs so it still stays plump. Check out the attached doc for common o-ring failures.
  11. Jun 20, 2023 at 5:21 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Should be able to just snug up the filter housing till you feel it bottom out, and stop there. It doesn't need to be socked down any tighter.
    golfindia and Rock Lobster like this.
  12. Jun 20, 2023 at 5:24 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    You don’t really need a torque spec and a torque spec is not what seals it. The housing threads in with about the same resistance all the way down to where it hard stops. That’s it.
    Oil is glossy. Perhaps you are seeing oil on the housing from your hands handling it during the change? Wipe it dry and monitor.
  13. Jun 20, 2023 at 6:10 AM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    Use brake clean on the housing to clean things up and check in a few days.
  14. Jun 20, 2023 at 6:17 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    These^^
    I found the stopping point to be pretty obvious even with my dumb ol' crafstman socket wrench. Its the one thing I like over the can filters seen on other cars - easy to snug, and easy to remove.
  15. Jun 20, 2023 at 7:36 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    If you don’t put a good amount of oil on the o-ring, it can start to bind up in there and cause a torque wrench to click at 18 ft. lbs. way before the canister is in all the way. Lube the o-ring and it’ll turn a lot easier. Forget the torque wrench and just feel it bottom out where it’s supposed to and snug it.
  16. Jun 20, 2023 at 7:55 AM
    zoo truck
    None
    Same for my craftsman socket wrench. You can easily feel when the housing threads stop.
  17. Jun 20, 2023 at 8:15 AM
    099
    I oil the o-ring and the threads. Easy on-- easy off.
