Oil Filter Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTNGURU, Jul 12, 2010.
  1. Jul 12, 2010 at 11:10 PM
    MTNGURU
    MTNGURU [OP] New Member
    First time poster, major issues. So new to the Tacoma community, hello everyone.
    Here I am attempting to change my oil for the first time and I am having issues. I was a jeep owner before and have changed my own oil for years. Here I am trying to remove the oil filter and having some difficulty. The filter has been placed and tightened so tight that it will not come off. I have bought an oil filter wrench and instead of removing the filter, it has torqued it like a can of soda and twisted it in place. Now the oil remaining has drained out but I have this twisted, cracked filter hanging off the engine....wtf? Thanks for the help, now and in the future.
  2. Jul 12, 2010 at 11:18 PM
    JKD
    JKD Well-Known Member
    Among other options:
    1. Get a strap type filter wrench, put it as close to the bottom of the filter as you can.
    2. Get a hose clamp large enough to go around the filter. Put it on as close to the bottom of the filter as you can, with clearance around the screw housing. Tighten it well. Use the screw housing as a leverage point to turn the filter.
    3. Stab the filter all the way through with a long, heavy screwdriver. Break it free with the screwdriver.
    etc. etc.
  3. Jul 12, 2010 at 11:18 PM
    SandyEggo
    SandyEggo Member
    So Cal
    2013 Prerunner SR5 access Cab
    Grab that thing at the base with the filter wrench and tap on it with a mallet while turning. Use big channel locks if the filter wrench wont do it...... and remember lefty loosy, righty tighty.
  4. Jul 12, 2010 at 11:22 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    HHmm. I'm not to sure what would work. Is this the original filter?
    My only two ideas are to heat it, which would be really hard because of it's location.
    Or get 2 pairs of pliers clamp onto it and try and twist. Don't let any metal shavings fall into the hole.
  5. Jul 12, 2010 at 11:25 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    You could take chisel or similar and using a hammer gently tap it against the rim of the base so as to loosen it. Similar to the approach used to loosen the top on a jar that won't come off by taking a non-sharp general use kitchen knife and hitting the outer rim of the top in the direction of the spin that loosens the top
    Convoluted explanation but I think you get the picture.
  6. Jul 12, 2010 at 11:36 PM
    MTNGURU
    Maybe you have different Tacomas than I have but there isn't much room to work with down there. I'm gonna wait till daylight to make another attempt but I don't know where you have room to fit in a chisel and hit it with a hammer.
    Oh and righty tighty, I hadn't thought of that, thanks....not. :)
  7. Jul 12, 2010 at 11:42 PM
    Peru
    Jonathan
    Redmond WA
    none
    Sorry -- I assumed you had the 4l v6
  8. Jul 12, 2010 at 11:42 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    MTNGURU, do you have the 2.7 4 cylinder engine? If so, I have the same, and had the same issue on my first oil change. I ended up crushing the filter just like yourself with a strap wrench and had to shove a massive Phillips head screw driver straight through the filter in order to break it loose. It was one hell of a chore getting the screw driver in the filter due to the lack of room to hit it with a hammer, but it can be done. Just take your time and be patient. It will come off eventually. You can thank automated assembly systems for your troubles..
  9. Jul 13, 2010 at 10:15 AM
    MTNGURU
    Thanks for the help. Here we go round two.
  10. Jul 13, 2010 at 10:25 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    My 2.7 oil filter was a bitch to get off too, but with a quality metal strap wrench it came off. I don't think Toyota oils the seal before the 800 lb gorilla installs it.:rolleyes:
  11. Jul 13, 2010 at 10:44 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    My wife's Xterra was like that the first time, they torque them from the factory like crazy...I tried my hardest and eventually took it to sears and let them deal with it...and any problems if they broke it.
    Regardless, that doesn't help right now. I suggest the same, use a screw driver. For future attempts (or anyone else reading this), try warming up the engine first. Besides allowing the oil to flow out better during the change, it warms up the area around the filter and may allow it to be removed easier.
  12. Jul 13, 2010 at 4:22 PM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    '06 Tacoma xtracab BB
    On my 2.7 the original oil filter was extremely tight also. I was able to break it loose using a pipe wrench. It is tight under there and you have to wiggle it around some to get it on the filter. It worked for me so it might be worth a try.
  13. Jul 13, 2010 at 9:19 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    They are put on with a dry seal and using an automated tool that counts turns and torque applied. This is then feed into a computer that monitors the assembly quality as the engine goes down the line.
    This is usually why factory new engine OEM filters are of different construction with thicker gauge metal cans. The thicker metal cans are more to withstand the automated install process.
  14. Jul 13, 2010 at 9:31 PM
    jassco
    jassco Well-Known Member
    Boston
    2010 Access Cab 2.7L SR5 5spd, 4x4
    5100 set to .85 w/ rear TSB, 2012 Rear-view Mirror, Grillecraft, Team Trails FJ Wheels, TPMS canister, Rear headrest delete, Rear console delete, Valley Hitch, Frame undercoat, $2.99 Tailgate hose clamp lock, Avid light bar, 4x4 lighted switch ala Biceman.
    I had the same problem with my first change. Two trips to the store and I finaly had a nice spring loaded filter wrench that fits on the end of an extension. It tore into both sides as it clamped tighter before the filter let loose and started to spin. Be carful not to damage the mount as others mentioned. Good luck.
  15. Jul 16, 2010 at 9:39 AM
    MTNGURU
    I finally tapped a heavy gauge screwdriver into the filter and it twisted off like a charm. I should have taken a picture of it, it looked like a twisted soda can that I then used for target practice:D
    Thanks for all the help, tips, and tricks.
