oil filter leaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JJPF, Jan 9, 2008.
  1. Jan 9, 2008 at 10:42 AM
    JJPF
    JJPF [OP] Member
    Dillingham Alaska
    07 access cab sr5 2.7 5 spd
    Hello, I'd like some opinions on a problem I have with my Tacoma. I bought it new this July changed the oil @ 3k with Amsoil OW-20 and an Amsoil Ea057 filter. Well this weekend it got down to -20 and when I started the truck I noticed oil leaking so I shut it off and climbed under, saw it was the filter so I hand tightened it and got maybe a 1/2 turn. Started it up no more leak. Started it mon morning before work and watched for a while and noticed it leaking again. Checked filter again maybe got an 1/8 of a turn, started no more leak. That night installed a oil pan heater, changed the filter, started it, watched for 10-15 min, no leak. Next morning plugged it in @ 615 am started it up @ 730, leaking again. Bought a timer for heater set it for 400 am, started @ 730 leaked about 3 drops. Should I snug it up a little more with a wrench? Anyone else have this happen? Any/All advice appreciated.
    JJPF
  2. Jan 9, 2008 at 10:57 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I don't know about the cold, but I'm curious if you put any oil on the seal before screwing it on.
    If you still can't get it, throw some red loctite on it and forget about it.
  3. Jan 9, 2008 at 11:04 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    Are you sure that it's the oil filter? Diagnosing the culprit of a oil leak is tricky sometimes. Oil will just slowly flow down to the lowest point on and drip from there, many people think the point that the oil is leaking from is the cause, many times it isn't. I guess what I'm saying is before you go through too much work to fix this problem. I would probably get some of that oil additive that you add to your oil and get a black light so you can find out where it's really coming from. If it is from the oil filter, then like others have suggested, did you oil the gasket before replacing the filter? If that doesn't fix it, then the next cheapest solution is to change the filter, if that doesn't work then I would look at the oil filter housing.
  4. Jan 9, 2008 at 11:20 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Did you use wrench when you first installed the filter. I'm worried that maybe it got crossthreaded. I'd hope that everyone would know if they did that.
  5. Jan 9, 2008 at 11:31 AM
    JJPF
    JJPF [OP] Member
    Dillingham Alaska
    Yep, I oiled the gasket. It didn't leak until this last weekend- the coldest day of the year so far. And yes I'm sure it's the oil filter thats leaking. Some of my buddies are thinking it could be a combination of the gasket shrinking and the light weight synthetic oil. Thinking about trying a different type of filter next. Thanks for the input.
    JJPF
  6. Jan 9, 2008 at 2:39 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'd definately change the filter and see if that helps. The cold weather shoudln't have any affect on the oil/filter - atleast, the filter should be designed properly to prevent that.
    Perhaps you got a bad batch of filters?
  7. Jan 9, 2008 at 3:26 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Only time I've had oil leak it was my own stupid fault... I didn't notice the gasket from the old filter still stuck to the engine so there were 2 rubber gaskets on after I put the new filter on. One of them bulged out and shot oil all of the engine... What a f'n mess! Needless to say I double check that now! :laugh:
    I only put mine on hand tight, and (guaranteed) I need a wrench to get the bastard off next oil change! Damn things seem to self tighten between changes. So I can't imagine having to re-tighten it each day.
  8. Jan 9, 2008 at 4:45 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Damn good question, I would think marking is a pretty smart ! :D
  9. Jan 9, 2008 at 5:35 PM
    JJPF
    JJPF [OP] Member
    Dillingham Alaska
    No I didn't mark it, but I think I've got it figured out now. I was looking at the box that the filter comes in and it says to go hand tight plus 3/4 turn or at least that's how I'm interpetating it. It dosent have words just pictures. Anyone else using Amsoil filters on their 4 cyl's? Usually hand tight is plenty but on the 2.7 they have a shroud that wraps 1/2 way around the filter making it hard to get a good grip on it. So I guess I'll snug it up with a wrench. Thanks for the input
    JJPF
  10. Jan 9, 2008 at 5:47 PM
    concrete jedi
    Rochester N.Y
    Good to you !
  11. Jan 9, 2008 at 7:26 PM
    Janster
    Jandy
    Lancaster, PA
    That's always been the *norm* for any oil filter.....atleast, that's what I've always known. But that depends on where/when you consider it *tight* and the muscles you have in your arms.
    Being a woman, I get it hand tight and then use both hands and go around about one full turn just to make sure.
