Oil filter O ring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GCC, Nov 22, 2023.
  1. Nov 22, 2023 at 1:22 PM
    GCC
    GCC [OP] Member
    George
    2018 Toyota Tacoma
    I just did my first oil change on my new (to me) 2018 Tacoma. WhenI took the cap off I found an O ring at the base of the perforated tube. It looks to be identical to the small O ring on the drain cap. I have never seen any mention of this in any posts. My question is is this supposed to be there or did a previous oil changer install it. Thanks
  2. Nov 22, 2023 at 1:31 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Check out post #4 to see the proper position of the O-ring.
    https://www.tacomaworld.com/threads/oil-filter-housing-issue.721660/
  3. Nov 22, 2023 at 2:52 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    na8rboy and TA2016[QUOTED] like this.
  4. Nov 22, 2023 at 3:16 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pics would help. There's only 2 o-rings, a big one and a smaller one
    TnShooter and Chew like this.
  5. Nov 22, 2023 at 4:03 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    So as the OP describes it, somebody put an extra O-ring inside the filter cap. It’s over the center tube, & would be under the filter element when it’s installed.
    Yet this is another reason why I don’t let dealerships or grease monkeys at some fast change oil place mess with my truck.
  6. Nov 22, 2023 at 6:54 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Not supposed to be there. It's possiblity from a "performance" filter, I think even the TRD uses them on the filter element. The standard Toyota filter just has a soft-ish material on both ends.
    TheDanimal likes this.
