Oil Filter on 2016 Tacoma
Discussion in 'Technical Chat' started by ToyTim, Sep 21, 2015.
  1. Oct 10, 2015 at 9:04 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    According to the diagram, looks similar to the 2010-current 4runner canister. Take like 1 1/2 hrs to to the oil change. The canister oil kit is not any cheaper than the regular swapping out filters.
  2. Oct 16, 2015 at 9:10 PM
    Soundwave
    Soundwave Well-Known Member
    B.C. Canada
    2013 TRD sport Double Cab 4x4
    OEM Roof rack
    yeah, same as the 4runners... probably same part #? I wonder is there are less skid plates and plastic covers to remove than the 4runner?
  3. Oct 17, 2015 at 1:53 AM
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    Bump for the guy who didn't want to forum today
  4. Nov 12, 2015 at 12:04 PM
    gaitkeeper
    gaitkeeper New Member
    David
    Raleigh
    2016 Barcelona Red TRD Sport V6
    A couple of questions:
    1. I'm getting conflicting advice on the size of the oil filter cap wrench that I need. Autozone chat rep says 32mm, Toyota parts rep says he "thinks it's 64mm". That's a big difference, and a big difference in price!
    2. OEM filter, FRAM or Purolator?
  5. Nov 12, 2015 at 12:12 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Can't comment on the size of cap wrench, but stay away from Fram. OEMFTMFW!
    shakerhood and robssol like this.
  6. Nov 12, 2015 at 7:37 PM
    gaitkeeper
    David
    Raleigh
    Right, should be 14 flats and 64mm. At least I hope so, cause that's what I bought.
  7. Nov 12, 2015 at 7:56 PM
    gaitkeeper
    David
    Raleigh
  8. Dec 12, 2015 at 5:03 PM
    rolexus
    rolexus Member
    2016 Toyota TRD Sport Super White
    The canister-type filter just takes a bit of getting used to. In addition to the environmental considerations, the unit is much less likely to collapse, due to any production flaws that may be present with screw-on type filters. Tips: (1) Use a small amount of aluminum foil on the inside of the filter wrench. This will help assure a good fit, and with decoupling the the housing from the wrench, and (2) add a short length of plastic tubing to the plastic filter drain insert, so that the oil can be more easily directed to your catch basin. My '13 Lexus ES 350 uses the exact same canister filter setup. Also, there is NO NEED to torque the housing or the filter drain cap excessively. Light torque after after the housing touches the block, plus the expansion caused by the heated engine, are plenty to assure that neither will become dislodged while driving. Finally, don't forget to remove the oil-fill cap and slightly lift (or completely remove) the dip stick, while the oil is draining. This eliminates any vacuum that may slow draining, or cause "spitting" toward the end of the draining process. Caution: The metal-type housing is made of a very low quality material, so with slightly oily hands, it can be easily dropped and cracked.
    I hope you find value in this post, as you no likely have from so many of the other highly informative comments you'll find on this forum.
    Kilokato, robssol and DoorDing like this.
  9. Dec 12, 2015 at 5:53 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  10. Dec 12, 2015 at 6:15 PM
    KenLyns
    Belly of the Beast
    They make "specialty funnels" as well:
  11. Dec 16, 2015 at 10:35 AM
    VinTaco
    VinTaco Well-Known Member
    Burnaby bc
    2016 Black Tacoma TRD OR
    Has anyone found the proper removal tool for the Tacoma on line..? The dealer here wants about $50 for the tool.. crazy
  12. Dec 16, 2015 at 7:20 PM
    IsraelDF
    IsraelDF Member
    2015 Tacoma 4x4
    None
    I am not sure there is any benefit in changing oil the first 100 miles. The dealer will typically do your first change at 5k or 10 free.
  13. Dec 16, 2015 at 8:19 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Don't forget your 2.7L water pump gasket:
    HunterBella and 12TRDTacoma like this.
  14. Jan 7, 2016 at 6:26 PM
    retired mech
    retired mech Well-Known Member
    Tom
    St louis,Mo.
    2016 sr5 double cab v6 4wd
    Does the element come with an o ring? It is always wise to change the o ring also. Most big truck elements come with one.
  15. Jan 7, 2016 at 6:33 PM
    #35
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    to each his own, let him spend his money how he wants in peace.
  16. Jan 7, 2016 at 9:50 PM
    #36
    Bishop84
    Bishop84 Well-Known Member
    All toyota cartridge filters come with housing orings and a drain cock with its own ring ;);)
    Most pros don't use the drain spout and just remove the cartridge whole and deal with the mess. It's crucial that there's lube on the oring when reinstalling or they will bind and leak. I use the engine oil as a lubricant but many use silicone spray.
    I love the 1GR oil change due to easy access and cursed when the FJ and 4runner got the cartridge style to go with the dual VVTi. Now we get to deal with it on all the trucks except the ancient 2.7
  17. Feb 17, 2016 at 10:22 AM
    #37
    Kingair84
    Kingair84 Well-Known Member
    Wisconsin
    2016 Double Cab TRD Off Road 6 speed MT
    Rad Industries skid plate, trd pro grill, rigid DOT Fogs
    Do any of you know if the filter comes with a gasket for the oil pan drain bolt?
  18. Feb 17, 2016 at 10:57 AM
    #38
    retired mech
    Tom
    St louis,Mo.
    No it does not, but the gasket (washer) should be good for a couple of changes anyway.
  19. Feb 17, 2016 at 11:03 AM
    #39
    Kingair84
    Wisconsin
    Great thanks for the quick response.
  20. Mar 6, 2016 at 2:41 PM
    #40
    desert dream'n
    desert dream'n Member
    2016 Tacoma TRD Sport
    So I was able to get the oil plug out and I inserted the plastic drain "thingy", but hardly any oil came out? Pulled out the dipstick and oil filler cap off, still nothing? Then I started unscrewing the filter housing and I got oil, but not a whole lot more and certainly not 6 quarts. I checked the dipstick and it still registers oil? Why can't I get the oil to drain?? Please advise!
