Oil filter plugged clogged up w/ 10k on V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Teocalli, Sep 30, 2008.
  1. Sep 30, 2008 at 7:51 PM
    Teocalli
    Teocalli [OP] Member
    '08 TRD
    Yo! Changed the oil today. Filter plug was totally clogged with gunk. Any idea how to prevent this.
    T
  2. Sep 30, 2008 at 7:58 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Filter plug?
    Are you referring to the hole at the bottom of the oil catch cup ?
    What's it clogged with?
  3. Sep 30, 2008 at 7:59 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    what is a filter plug? lol
  4. Sep 30, 2008 at 8:02 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
  5. Sep 30, 2008 at 8:02 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I didn't know what it was either and decided to wait for the answer. I feel better knowing I was not the only one. lol.
  6. Sep 30, 2008 at 8:03 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
  7. Sep 30, 2008 at 8:11 PM
    Teocalli
    '08 TRD
    Sorry for the lack of clarification. The plug in which the oil drains out of when you unscrew the filter. Plugged with gunk, debris, dirt... Any explanation. Thanks for the quick replies by the way.
  8. Sep 30, 2008 at 8:12 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Yo no freakin idea!
    j/k with ya!
    Still have no idea and will wait for those much more knowledgeable than me.
  9. Sep 30, 2008 at 8:17 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    Was this your first oil change in 10000 miles?
  10. Sep 30, 2008 at 8:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes, I am. LOL
    And THIS was my first question! :D
  11. Sep 30, 2008 at 8:22 PM
    Teocalli
    '08 TRD
    Second oil change in 10K. Probably 2000 miles of off-roading on the truck. First oil change I had done at the dealership around 4,800. Switched to synthetic.
  12. Sep 30, 2008 at 8:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When changeing the oil, make sure to clean out the cup that the oil filter sits in. If you leave oil in it, it will collect all sorts of dirt and whatever in it. Just wipe it down with a clean rag, and you should be good.
  13. Sep 30, 2008 at 8:31 PM
    Teocalli
    '08 TRD
    Thanks. This makes sense. Do you think the mechanics at the dealership would of been so neglectful the first go around? Can't trust anyone these days.
  14. Sep 30, 2008 at 8:35 PM
    Teocalli
    '08 TRD
    Here's the truck by the way...
  15. Sep 30, 2008 at 8:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Absolutly. If its that dirty, just hold some rags under it with the plug out, but oil filter ON, and spray some break cleaner to clean it out. I know some people are going to say "WHAT!!!!!!!!!!!??????" No break cleaner by the oil filter!!!!!!!
    Trust me, it will be fine.
    Nice truck! :)
  16. Sep 30, 2008 at 10:08 PM
    Bubba-Jet
    Bubba-Jet Active Member
    Wyano PA.
    07 Tacoma SR5 TRD 4X4 Sport
    Removed Secondary Air Filter,Tacomaworld Sticker,Wade In-Channel wind deflectors,Fumoto 12mm.F103N Engine Oil Drain Valve,Home Cast Bed Tie-downs
    If I remember correctly. There is a red cap over the nipple on the bottom of the cup to catch the oil below the filter.
    With a Fumoto oil plug and a 3' long hose I can change my oil without spilling a single drop. Nice and Clean oil changes.
  17. Oct 1, 2008 at 2:13 AM
    Janster
    Jandy
    Lancaster, PA
    X2
    Filter on for sure... and the engine COLD!!
    Highly flammable brake cleaner & hot engine ...really really bad idea!
  18. Oct 1, 2008 at 3:13 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Be happy it was clogged. It kept the oil from leaking all over your frame & driveway.
    Nice truck!
  19. Oct 1, 2008 at 10:22 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    when u guys drain the oild? then the oil filter? how much oil will it leak out from the filter? alot?
  20. Oct 1, 2008 at 10:37 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I'm guessing not much. Since the filter is inverted, I'd probably let the truck sit for a while after running the engine to make sure that gravity has some time to do it's job before removing the filter.
