Oil Filter Poll!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan1911, Apr 22, 2013.
Oil Filter Poll!!
  1. Fram Ultra
    6.7%
  2. Mobil 1
    10.2%
  3. Toyota OEM
    79.4%
  4. Bosch
    3.7%
  1. May 1, 2013 at 8:11 PM
    #61
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Many filters will physically fit our engines.
    That doesn't mean they are correct.
    There are two different thread pitches that are very close together and the filters will generally fit, but they are not fully secure.
    Also, the main issue, is the bypass valve.
    Different engines have different bypass valve specifications, and in some engines, NO bypass is desired because it is internal to the oil pump (the old SBC was like that).
    Yes, the standard Ford filter (PH8A cross reference) used to be the specified Toyota filter up until some time in the mid 1980s... but it is no longer the "correct" filter and using it could be pointed to by the dealership as a reason for denying warranty service.
    Also, just because a filter can is larger does not mean that it uses a larger filter element than a filter half it's size.
    The OEM filter does a perfectly fine job, it's cheap, and it is readily available. There is no reason to screw around with alternatives. It's not like we're driving some oddball vintage import no longer made, needing improvisation on maintenance parts.
  2. May 1, 2013 at 8:23 PM
    #62
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    There was a video done a while back and may have been someone on TW that opened all the filters and did a comparison on all of them. Toyota's filter was the best hands down.
  3. May 1, 2013 at 8:24 PM
    #63
    NorCalTRD
    NorCalTRD Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
  4. May 1, 2013 at 8:43 PM
    #64
    Rich91710
    Rich
    Los Angeles
    08 Base
    That was Moderator and current Heep owner: Chris4x4
  5. May 1, 2013 at 8:51 PM
    #65
    Brian007Taco
    Ah, I see.
  6. May 1, 2013 at 9:22 PM
    #66
    LocoTaco
    LocoTaco Well-Known Member
    Don
    Central Washington
    09 SR5 TRD Sport
    OEM for me and Mobil 1.
  7. May 2, 2013 at 2:27 AM
    #67
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    OEM or Wix...never heard any complaints about Wix
  8. May 3, 2013 at 5:19 PM
    #68
    sportsterchop200
    sportsterchop200 Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    So how long will a OEM filter last if your running a 7500 or 10000 mile synthetic like Amsoil or some other brand?
  9. May 3, 2013 at 7:54 PM
    #69
    Rich91710
    Rich
    Los Angeles
    08 Base
    Toyota factory-fills with Mobil-1 on the new 2.7, but still recommends 5000 mile intervals.
    10,000 mile intervals are approved for other vehicles, but not the Tacoma (and some others).
  10. May 13, 2013 at 6:16 AM
    #70
    HMA
    HMA Well-Known Member
    Hal
    Bainbridge, Ga
    '10 Taco Surveying Machine '22 Lunar Rock
    Be careful doing that. I looked at finding a filter with a bigger can with my NAPA guy a while back. We found several that would fit, but none had the correct bypass or drain-back valves. I don't remember the part #'s for the ones we found. BTW, the 51348 also fits most Briggs & Stratton lawn mower engines.
  11. May 13, 2013 at 6:28 AM
    #71
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    FRAM coz it's need no tool to take it off...
  12. May 15, 2013 at 5:42 PM
    #72
    FlawlessPeace
    FlawlessPeace Member
    Allen
    Duke City
    08 prerunner
    Wix 51515 change every 3k miles
  13. Jun 9, 2013 at 7:00 AM
    #73
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Mobile 1 and TRD High Performance oil filter (PTR43-00080).
  14. Jun 10, 2013 at 6:27 PM
    #74
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    I called my local Toyota dealership Saturday to get my first oil change since I bought my "used" truck in December. They wouldn't answer so I went in and bought a OEM Toyota oil filter. I went down to the Citgo where I used to get my silverado oil changed. They gave me a $2.00 oil filter credit since I brought my own. The manager came inside and asked me if Toyota said that I had to use their oil filter and I said no they didn't but I heard that the Toyota's filter has a spring in it that makes it the best or one of the best filters for my truck. He said that he Citgo brand or their brand had the spring inside theirs. He gave me an explaination of what it did. Does anybody know if this is true or not? I was going to buy 1 Toyota filter but the lady said if I bought 2 or more then it was $4.95 per filter. So I got 2 filters for $10 and some change after tax.
  15. Jun 10, 2013 at 7:57 PM
    #75
    Rich91710
    Rich
    Los Angeles
    08 Base
    Stick with the Toyota filter.
    I have no idea what "spring" you are talking about, but there are many other reasons that the Toyota filter is one of the best you can run.
    As far as price, you can get them for $4 each online in boxes of 10... but 2 for $10 isn't bad.
  16. Jun 10, 2013 at 8:18 PM
    #76
    WABOOM
    WABOOM Well-Known Member
    Minnesota yeah sure ya betcha
    2013 F-150 XLT Supercrew 4x4
    debadged
    LOL people use Fram??? why?
  17. Jun 10, 2013 at 8:35 PM
    #77
    Rich91710
    Rich
    Los Angeles
    08 Base
    30 years ago they were a good filter.
    Their air filters are still good, as are their cartridge oil filters and Diesel fuel filters.
  18. Jun 11, 2013 at 4:14 AM
    #78
    DBTaco
    NC
    I thought I read or someone told me that the Toyota oil filter had a spring in it that would either regulate or something to do with the oil pressure. What makes the OEM filter better, if I could get a quick run down of why? Going to look at the comparison thread to see if I can find out also.
  19. Jun 11, 2013 at 8:00 PM
    #79
    Rich91710
    Rich
    Los Angeles
    08 Base
    The Toyota filter, and most all other filters have a bypass valve that allows oil to bypass the filter media, allowing dirty oil to enter the engine, should the filter element become clogged.
    There's nothing "special" about the Toyota filter other than it is a very high quality filter element and housing.
  20. Jun 12, 2013 at 9:26 PM
    #80
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Because Fram has a good marketing dept and has struck deals to line Walmart shelves with them.
