Oil Filter Poll!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan1911, Apr 22, 2013.
Oil Filter Poll!!
  1. Fram Ultra
    6.7%
  2. Mobil 1
    10.2%
  3. Toyota OEM
    79.4%
  4. Bosch
    3.7%
  1. Oct 30, 2013 at 6:56 AM
    #161
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Who here also believes that the trd oil filters are just k&n filters that have been painted black and a trd sticker put on then. They look exactly the same (have not taken either apart, just from the outside they look the same). They are the only two oil filters with a 1" nut on the end....that i know of...
  2. Oct 30, 2013 at 8:24 PM
    #162
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    K&N and M1, supposedly also Royal Purple, are the same filters, made on the same line by Champion Labs.
    K&N has the nut, M1 and RP don't.
    But I would like to see an RP opened up and compared to the M1... I have not seen the claim that it is the same from a credible source yet.
  3. Oct 30, 2013 at 9:34 PM
    #163
    AR15xAR10
    I'll just put k&n stickers on my truck and tell those who don't like it to piss off. I'll run oem or oem trd, or m1, or k&n. i would religiously use only the m1 or k&n if they came with drain plug gaskets....i want a sack of ghose damn gaskets!
  4. Oct 30, 2013 at 9:37 PM
    #164
    Rich91710
    Rich
    Los Angeles
    08 Base
  5. Oct 30, 2013 at 9:39 PM
    #165
    AR15xAR10
  6. Oct 30, 2013 at 9:45 PM
    #166
    AR15xAR10
    A heated up copper washer? I'm not following....
    The oem ones are aluminum with a little bit of rubber on each side. I would think the copper would crush easier than the aluminum....
  7. Oct 30, 2013 at 9:57 PM
    #167
    AR15xAR10
    I see now what you mean. I wouldn't know here to get a copper gasket that fits perfectly so i'll just buy a sack of oem ones for now.
    Thank you for your patients in dealing with my ignorance.
  8. Oct 30, 2013 at 10:49 PM
    #168
    Rich91710
    Rich
    Los Angeles
    08 Base
    Drain valve.
    Flip the lever, oil comes out.
    If you have a V6, you can change your oil in a nice shirt.
    2.7 filter still requires something you don't mind getting oil on and grinding into the driveway.
  9. Nov 2, 2013 at 7:28 PM
    #169
    Rich91710
    Rich
    Los Angeles
    08 Base
    The Suredrain is the only option that works on low-clearance engines like my wife's '04 Rav4.
    The drain is on the rear of the pan, but angled down 45 degrees.
    While I would not trust the unit to seal, the dust cap has an o-ring that will retain the oil should the disk seal fail.
    Changing the oil on her Rav is a dream. Crank the wheel to the right and I can do the entire job kneeling by the front tire.
    The filter and drain are right there.
  10. Nov 2, 2013 at 8:11 PM
    #170
    Rich91710
    Rich
    Los Angeles
    08 Base
    Gorilla fingers ;)
    Seriously... I put it on hand-tight, but usually need pliers to break it loose.
    But in almost 10 years, I've never seen any evidence of leakage from the disk valve. There's just a small dab of oil in the cap from the small amount that hangs around after removing the tool.
  11. Nov 29, 2013 at 10:51 AM
    #171
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    No kidding. I've got a whole Haz-MAT suit I've pieced together for that job.
    NAPA Gold Filter by the way. . .[WIX]
  12. Dec 1, 2013 at 11:34 AM
    #172
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Oh someone is very safety oriented. :)
  13. Dec 18, 2013 at 10:07 AM
    #173
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    I was using Purolator, now I've got a FRAM.
  14. Dec 18, 2013 at 10:10 AM
    #174
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I'd rather use a coffee filter :cool:
  15. Dec 18, 2013 at 10:17 AM
    #175
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
  16. Dec 18, 2013 at 10:47 AM
    #176
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Toyota
  17. Dec 18, 2013 at 3:33 PM
    #177
    jw1983
    Alberta
    Mmmm! Coffee!
  18. Dec 18, 2013 at 3:42 PM
    #178
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    OEM & Mobile 1 fully synthetic.
  19. Dec 18, 2013 at 8:09 PM
    #179
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    ^ that
  20. Dec 14, 2015 at 5:47 PM
    #180
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    If you read up on the Fram Xtraguards they are as good if not better than all other filters.
