Oil Filter Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RCL, Nov 14, 2010.
  1. Nov 14, 2010 at 9:10 AM
    RCL
    RCL [OP] Well-Known Member
    Bob
    Oklahoma
    2010 TRD Dbl. Cab
    Winch
    I received a free Fram Xtra Guard oil filter when I purchased oil. I have been hesitant to use it as I have always used Toy filters.
    Anyone know of any problems using this filter?
  2. Nov 14, 2010 at 9:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Check out Bobistheoilguy.com
    Fram are kind poor quality filters. I would dump it and run OEM.
  3. Nov 14, 2010 at 9:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  4. Nov 14, 2010 at 9:22 AM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    This^^
  5. Nov 14, 2010 at 9:43 AM
    RCL
    Bob
    Oklahoma
    2010 TRD Dbl. Cab
    Winch
    Many thanks. Think I will stick with oem or purolator.
  6. Nov 17, 2010 at 8:57 PM
    gosu
    gosu New Member
    Greg
    Vegas
    Coming from Subaru forums I learned a lots.
    Fram is made from Honeywell, which sucks
    K&N (and mobil 1 i think) is made from Champion, which sucks and your paying 10$ more for a nut welded on the bottom of the filter
    From what ive researched for years and years pureone is good stuff.
    But now a days I guess you cant go wrong with any of them... just get a filter with the correct bypass valve pressure
  7. Nov 17, 2010 at 9:52 PM
    huckyourmeat
    huckyourmeat Well-Known Member
    Denver, CO
    10 TRD OR DC Silver
    I use the TRD filter. Expensive, yes, but they use synthetic media and are slightly larger than the stock ones. Better media and larger size (larger surface area) means better flow while maintaining the necessary filter efficiency.
    I figure it's worth a few extra bucks every 6 months for a little additional peace of mind. The 1" nut on the top also makes installation and removal easy.
  8. Nov 18, 2010 at 8:19 AM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
  9. Nov 18, 2010 at 8:34 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    there good for sighting in rifles
  10. Nov 18, 2010 at 8:39 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    On or off the truck?
  11. Nov 18, 2010 at 8:40 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    if the hoods up...i'll say on:D
  12. Nov 18, 2010 at 8:41 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I like the way you think............:cool:
  13. Nov 18, 2010 at 8:52 AM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    I too used Fram until I found out how cheaply made they were. i used Purolator Pureone now and have never had an issue. Originally I did not just go to Pureone. I had a JK at the time and it had a click clack on start up. I tried Mobil filters, Fram Filters, K&N filters, Napa (both Wix and one that did not say it was made by Wix) and all of these let the clicking continue (only on start up this occured) until I switched to the Purolator Pureone. that filter never had a click start again and I ran them until I got rid of that Jeep. I kept with the Pureone's as they make a great filter it has more pleats which is where the surface area is increased, and it has a silicone anti-drainback valve (which is what I think helped the clicking Jeep). Most of the companies out now don't make their own filters, they are made by the larger filter companies and re-badged. JOE>
  14. Nov 18, 2010 at 9:02 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i dont use FRAM, but i have. for years, i have used them. never a failure that i know of.
    but now that i'm older and wiser..i buy OEM.
  15. Nov 18, 2010 at 9:18 AM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    damn i gotta STP filter in the truck right now and i kinda knew going into it that i didnt like it but i couldnt find anything else. the Amsoils look nice too
    where do yall get these purolators at? autozone? oriellys?
    thats what ill be switching to
  16. Nov 18, 2010 at 9:25 AM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | Access Roll-up Tonneau Cover, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat ---------------------------- | INTERIOR | Flyzeye V2W (Amber/White/Amber) Audio: Alpine CDA-117, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    1992 Chevy Lumina, 175K miles
    1993 Nissan Hardbody, 175K miles
    1995 Toyota Camry, 260K miles
    All have had oil & filter changed @ 5K mile intervals. Used Fram oil filters & Castrol (dino) motor oil in them. An idiot, not me, ran a stop sign and killed the Lumina. It was still going strong at the time. '93 Nissan & '95 Camry still running strong. Makes me wonder if it has more to do with the oil & filter change interval than the products..? Oh BTW, I'm using Mobil1 synthetic oil & filters with my Taco because the person I bought it from was using it so I kept status quo.
  17. Nov 18, 2010 at 12:01 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    I never use Fram's. I use either wix, pure one, or oem.
