Oil filter question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dmicgrif, Mar 8, 2012.
  1. Mar 8, 2012 at 12:28 AM
    dmicgrif
    dmicgrif [OP] Well-Known Member
    mike
    kihei, maui
    2005, 4x4, 4 door, LB, black all over
    So tomm I am going to change my oil. I noticed that the filter is I guess you can say upside down. But I was talking to a guy a few months ago about changing oil on a cat 3406 deisel engine. The oil filter is mounted the same way. He told me to stab a hole in the filter before removing and wait a few minutes to remove it. He said it helps with letting all the oil drain before roming it and making a big mess. Has anyone done this before? If not I hope this helps.
  2. Mar 8, 2012 at 1:12 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    There's a drain hole on the bottom with a rubber plug on it... Remove the plug and place a bottle underneath to catch all the oil coming from the filter. No mess
  3. Mar 8, 2012 at 1:22 AM
    1980 Well-Known Member
    The Dust Bowl
    The 05+ Tacos have a funnel located under the oil filter with a rubber drain plug that can be removed to let the filter oil drain into a plastic pop bottle. Don't feel bad if you don't know this -- I changed the oil a half-dozen times in my '06 with a wad of paper towels ready to mop up spills, cussing the engineers each time for their "bad" design, before I read on this forum about the oil-filter drain plug.
  4. Mar 8, 2012 at 10:55 AM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Or attach a hose and run it down below.
  5. Mar 8, 2012 at 10:55 AM
    Mach375
    Someone didn't flip through his owner's manual. It's mentioned in there, both the cup-collection method and the hose-drain method.
  6. Mar 8, 2012 at 10:57 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Yes, have done this many times on different vechicles and machinery to avoid a mess. Takes longer then a few minutes, though!
  7. Mar 8, 2012 at 11:00 AM
    myname150
    myname150 Well-Known Member
    Loosen the oil filter, and have something like this at the bottom to collect the oil
  8. Mar 8, 2012 at 11:15 AM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    This works the best! get some 3/8" hose i believe it is and attach it to the small drain hole on the bottom and run it down through the skid and into the oil pan. have done this since I bought the truck and it does wonders! saves you from a lot of clean up. I have punctured the oil filter as well before and it still drains out. doesnt make that much of a difference in my opinion..
  9. Mar 8, 2012 at 11:20 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, but mine didn't have a rubber plug.
    OP, you can poke a hole in the filter and let the oil drain out, that works also but you will still have some oil that won't drain out and you'll have to use the catch cup method anyways.
  10. Mar 9, 2012 at 1:57 PM
    dmicgrif
    mike
    kihei, maui
    Thanks for the picture about to go and change the oil now.
  11. Mar 9, 2012 at 6:45 PM
    dmicgrif
    mike
    kihei, maui
    I did it. Haha, so I put a bottle under and it got most of the oil. I did have to take a rag and small screw driver to get the little bit that wouldnt go thru the hole. Thanks for the help. It was my first oil change on the truck.
  12. Mar 9, 2012 at 7:47 PM
    Eurosport
    Eurosport Well-Known Member
    around the world
    with an oil extractor it's even easier and don't even have to touch rubber plug, just suction by the filter as your unscrew it, keeps everything super clean
  13. Mar 9, 2012 at 9:27 PM
    myname150
    You're welcome.
    :thumbsup::
  14. Mar 10, 2012 at 4:13 AM
    The Dust Bowl
    I do like the new oil filter and drain plug positions in the 05+ models. Does anyone remember how hard it was to change oil in the late 1st gens? In my '03 not only did I have to take a half-dozen or more bolts lose to get to the plug, I about had to break by arm twisting around to get to the oil filter.
